Page 1 of 1
[ 5 posts ] |
| Author |
michaldana
Post subject: halicrafters model sky buddy (s19R ) Posted: Jun Thu 21, 2012 3:42 pm |
Joined: Apr Thu 02, 2009 8:10 pm Posts: 24 Location: upper darby, pa 19082
Can you help to find : switch AC ON-OFF for my S19R ( oryginal is bad ), i was tried on webs but no luck Thanks for any info
Michael
| Top |
Joe Connor
Post subject: Re: halicrafters model sky buddy (s19R ) Posted: Jun Thu 21, 2012 5:30 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 552 Location: Morris Plains, N.J. 07950
| Top |
Johnnysan
Post subject: Re: halicrafters model sky buddy (s19R ) Posted: Jun Thu 21, 2012 8:51 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 11441 Location: Albuquerque, NM 87123
Have you tried cleaning it, or is it broken?
Many of those toggle switches can be cleaned. This is what I do: Put the radio on its back, front facing up. Use a good control cleaner (I use Deoxit). Hold the spray nozzle at the base of the toggle and very gently dribble several drops of cleaner into round portion of the toggle. It will get inside. Let it sit for a while, then do it again. Actuate the toggle many times (like over a hundred). Measure the resistance of the switch; it should be close to zero.
I have saved probably at least 90% of the toggle switches by cleaning this way.
| Top |
Dave Doughty
Post subject: Re: halicrafters model sky buddy (s19R ) Posted: Jun Thu 21, 2012 10:09 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 13650 Location: Utica, NY 13502 (USA)
While Johhnysan's advice for cleaning toggle switches is spot on, the AC switch on this radio is part of the volume (audio gain) control. The switch portion can be cleaned if you remove the control from the chassis then remove the back assembly to gain access. But if the actual mechanism is broken, the best solution is to replace the control. Volume controls that have an attached AC power switch are fairly common.
| Top |
michaldana
Post subject: Re: halicrafters model sky buddy (s19R ) Posted: Jun Fri 22, 2012 5:05 am |
Thanx all for quick respond
Michael
| Top |
Page 1 of 1
[ 5 posts ] |
Moderator: Sandy |
