It is currently Sep Tue 19, 2017 11:37 pm
 Post subject: PL-108 Connector on a BC-1023-A Marker Beacon Receiver
PostPosted: Sep Tue 12, 2017 6:53 pm
I am trying to remove the PL-108 connector on the front panel of a BC-1023-A marker beacon receiver.
The problem is simple -- the connector will not clear the mounting hole. Does anyone have specific experience mounting/unmounting the PL-108 connector?
Curly
PL-108 Connector on a BC-1023-A Marker Beacon Receiver.jpg [ 89.63 KiB | Viewed 189 times ]
 Post subject: Re: PL-108 Connector on a BC-1023-A Marker Beacon Receiver
PostPosted: Sep Tue 12, 2017 7:07 pm
Hi "Curly",
No.
However, from here it looks like the top part is screwed onto the part that penetrates the front panel. And, it looks like there's enough room to grab the latter with channel-lock type pliers while you take off the top part with a wrench.
Of course this assumes you're not trying to save the connector.
Take care, my friend.
73, Chuck K4CCW
You can't reason a person out of a position they weren't reasoned into.
PostPosted: Sep Tue 12, 2017 8:05 pm
Hi Curly,
Since the knurled ring of the connector has wrench flats milled in the sides,
and there appears to be a junction line between that and the lower section...
One would expect the upper part to unscrew. Please use a proper wrench, not pliers.
The connector needs to be mounted to the panel as intended to provide support.
The connector may contain a fuse.
- Leigh
73 de Leigh W3NLB
http://www.AtwaterKent.info
PostPosted: Sep Tue 12, 2017 8:16 pm
Of course Leigh is correct, as he almost always is. :D
I should not have posted before the drugs for treatment for an attack by a swarm of bees has worn off.
As Gilda often said, "Never mind!"
73, Chuck K4CCW
PostPosted: Sep Wed 13, 2017 12:53 pm
Curly,
The PL-108 is a "Breeze" style connector where the panel mount portion of the connector has internal threads and the mating plug has external threads. If it won't turn freely with a wrench on the flats as Leigh suggested, you may need to put some sort of penetrating oil at the seam to help it out.
Sean
KBØOVD
If it ain't broke, take it apart and see how it works.
PostPosted: Sep Wed 13, 2017 7:01 pm
Thank you, Chuck, Leigh and Sean. Yes, the connector did unscrew.
I used a large crescent wrench with two layers of a repurposed aluminum soda can wrapped around the connector knurled O.D. Absolutely no damage.
It always bothers me when I see a beautiful Tek or HP with jaw marks on rounded off knurl nuts and panel damage!
Curly
PostPosted: Sep Wed 13, 2017 7:18 pm
VG
- Leigh
73 de Leigh W3NLB
Post New Topic Post Reply  [ 7 posts ]  Moderator: Sandy
