It is currently Jan Sat 19, 2019 3:40 am
 Post subject: Heathkit AR-2 Receiver
PostPosted: Sep Fri 14, 2018 4:26 pm
Hello everyone,
I have a AR-2 with SMD. Would anyone know the suggested capacitor values for both the 1st and 2nd IF cans ?
Thank you,
Bill
 Post subject: Re: Heathkit AR-2 Receiver
PostPosted: Sep Fri 14, 2018 4:46 pm
You can download a manual, which includes a schematic and parts list, here.
Hope this helps.
- Bruce K1FFX
PostPosted: Sep Fri 14, 2018 5:03 pm
Hi Bruce,
Thanks for the reply. I do have that manual but it only gives the part no. for the IF cans but does not indicate the actual values of the mica sheets inside the can which make up the capacitors for the primary and secondary sides of the coils.
Those mica sheets need to replaced with an actual capacitor such as a disc or mica type. My problem is, I don't know the correct values to use for each IF can. There would be two capacitors needed for each can.
Thanks Bruce.
Bill
PostPosted: Sep Fri 14, 2018 7:56 pm
Bill,
Use dipped mica and not disc capacitors for these replacements. Typical values I have run across are between 300-520 pf and most used the same value on both input and output sides but I am sure there are exceptions.
If you have a capacitance meter and one of the mica leaf type capacitors is still functional isolate and measure the capacitor. Alternatively you can use a signal generator and scope (or RF voltmeter) to measure the transformer and either try different mica values in the expected range OR use a variable capacitor to find what value is needed to resonate the winding. A grid dip meter with a 455 Khz. coil would work for measuring also but those aren't common.
I would tack in a couple of 510 pf capacitors and see if that allows the transformer to peak normally.
Rodger WQ9E
PostPosted: Sep Fri 14, 2018 9:11 pm
Hi Roger,
Sounds good. That gives me a place to start. Thank you for the advise.
Bill
PostPosted: Sep Sat 15, 2018 12:45 am
Rodger, my Knight Star Roamer had silver mica migration disease in its 455KHz IFTs. I removed the built in caps, and replaced them with external caps. IIRC, the new caps were just 100~120pF. I'll have to look inside to check.
Rob
PostPosted: Sep Sat 15, 2018 12:54 am
Thanks guy's, good info !!
Bill
PostPosted: Sep Sat 15, 2018 6:46 am
Checked the Star Roamer: I had replaced the original internal IFT caps with external 100pF mica, primaries and secondaries.
PostPosted: Sep Sat 15, 2018 2:22 pm
Thanks Rob - I'll try it.
Bill
Post New Topic Post Reply  [ 9 posts ]  Moderator: Sandy
Users browsing this forum: super skyrider and 8 guests
