It is currently Feb Sat 16, 2019 2:52 am
 Post subject: Kenwood ts 530 no output on some bands
PostPosted: Feb Mon 11, 2019 1:08 pm
I have kenwood ts 530s that has a lot of intermittent output on some bands. Sometimes 1.5 and 3.5 work then they won't some bands never work. Some work and then stop and the digital VFO screen goes blank . Is this dirty band switch ? If so what is the best way to clean it ? I have used CRC contact cleaner to no avail.
KM4YTW
 Post subject: Re: Kenwood ts 530 no output on some bands
PostPosted: Feb Mon 11, 2019 1:57 pm
Rich,
It could be band switch contacts but it could also be a problem with the PLL synthesizer section. The TS-530S is very different than its TS-520 predecessor and although it is generally reliable, it is far more complex. The band switch contacts usually aren't that big of a problem with this set so do a visual examination but the cleaner you used should be sufficient.
I would grab the service manual (it is available online) and start by making sure the regulated voltage adjustments are set correctly. Then check for output from the synthesizer section while also checking to see if the specified voltage for the VCO is correct for that frequency setting.
Rodger WQ9E
PostPosted: Feb Mon 11, 2019 3:11 pm
I'll add to Rodgers excellent advice.
Kenwood hybrids have two well known issues;
any level of moisture will cause corrosion to form on those
tiny connectors causing them to go intermittent. The second
is the PC boards did not have plated through holes. Cracked solder
joints, especially at connectors, is very common. I have seen
cracked joints at the variable caps on the RF board too.
Quite often just removing and re-inserting connectors is enough
to wipe off the corrosion. If you can track the intermittent down to a
PC board the best thing to do is remove it and inspect for
cracked solder joints.
Also, the 100 ohm cathode resistors for the
6146's drift high which will reduce output power.
The good news is once these issues are resolved these
rigs are very reliable.
Steve
PostPosted: Feb Mon 11, 2019 3:38 pm
Steve
MANY times I have "repaired" a desktop PC by disconnecting every plug (except the processor), and reconnecting.
PC boards: If you find more than a few cracked joints, reflow ALL of them.
-Mark http://pixellany.com
PostPosted: Feb Mon 11, 2019 5:51 pm
Thanks Rodger, Steve and Mark. I have some Deox coming and I think I will just go thru and clean all connectors and switches once more. Once I feel confidant that is no longer the issue I will start checking voltages for anything out of spec. I have already done the voltage adjustments and it's spot on with the service manual I got with the rig. Intermittent problems are so agravating. I'll let you know what I find .
KM4YTW
PostPosted: Feb Tue 12, 2019 12:42 am
I cleaned everything and found a terrifying task i have to do. Im gonna have to remove the rf board . When i went to disconnect connector 3 the whole connector just pulled out of the pcb. This looks like a horriable job. This thing looks like a errector set from hades. The band switch is connected , drive caps all the way into the finals. Any tips or how to do this will MUCH appriciated. This one board i was praying nothing was wrong with. Thanks.
KM4YTW
PostPosted: Feb Tue 12, 2019 2:42 am
Just make sure the finals are discharged so you don't get whacked! There's 800 volts or so that could be sitting in it!
Great web site here!
https://www.k4eaa.com/
Todd
PostPosted: Feb Tue 12, 2019 4:46 am
Good page Todd, Thank you
PostPosted: Feb Tue 12, 2019 9:04 am
Rodger that . I either let it set or discharge that thing. Things
KM4YTW
PostPosted: Feb Tue 12, 2019 11:43 am
I found WB4HFN . He has a good download on rebuilding the band switch. Pretty good written explanation of how to do it. It's a PDF download under his kenwood section.
KM4YTW
PostPosted: Feb Thu 14, 2019 12:36 am
I got the band switch out and removed the band switch wafers , cleaned them up nice and shinny , checked resistance . Several were high . I got them all down from 1.2 ohm to .1 ohm. One of the tabs on the wafer switch was bent out of position . A couple din connectors pulled out of the board . Ill take marks advice and reflow everything . It appears a couple diodes have been removed. Ill have to check it closely.
What is the best way to reflow these joints? Flux and a hot iron ?
KM4YTW
