| Author |
Mikeinkcmo
Post subject: E.F. Johnson electronic TR Switch Posted: Jul Thu 21, 2011 2:26 pm |
| Top |
Avery
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Thu 21, 2011 3:18 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 1588 Location: Potomac, Md.
Johnson did believe in line filtering, didn't they? Love all those little inductors and caps! Reminds me of the underbelly of the Ranger that got me through my General ticket years in the '50s-early '60s. I think the Ranger might even have had two LC sections back to back.
But that was back when TVI was a real problem if you operated on 15M, close to the TV IF frequency, which I dimly recall was 21.25mc. Hence the Ranger's copper fingerstock and meter shielding in addition to the line filtering.
_________________ Avery W3AVE
| Top |
Peter Bertini
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Thu 21, 2011 3:40 pm |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 12448 Location: Somers, CT
Hi Mike
I always wanted to homebrew one of those. Can you tell me what the RF transformer looks like, and how it is constructed? EFJ didn't provide much information on the turns ratio, etc. Looking at your print, T2 almost looks like it could be a RFC with a tapped winding, looks to be 2500uH or so? Can you see if was tapped, or did they add a winding over the pi wound coil? BTW, I'm sure you know this, but that should be located as close to the TX as possible, since they used the PA tuning for the T-R Switch input tuning. I don't know if you're planning on a HT-32, but I surmise the Johnson T-R switch won't work with that TX because the driver and PA stages are biased in AB1 whenever the transmitter is turned on... I'd expect too much white noise is being generated during standby. The manual mentions that is a concern with some TX modes, but no specific examples were given.
The switches also generated harmonics, so most hams used a low pass filter in the line before the antenna. W8JI did an analysis of the switching time on his website; it is also not a good mate for a solid state RX.
Pete
_________________ A long journey always begins with the words, "I think I know a shortcut."
| Top |
Rich, W3HWJ
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Thu 21, 2011 4:16 pm |
Joined: May Tue 30, 2006 4:46 pm Posts: 4880 Location: Santa Rosa, CA
Quote: The problem of receiver audio muting during transmit, still needs to be addressed though. I used the Johnson T/R for years with my DX-40 and NC-109 on AM. I had an external PTT relay that keyed the transmitter and disabled the receiver. The NC-109 had an accessory socket on the back that gave access to the receiver, but I can't remember if it killed only the audio or the whole B+ ?? And, yes, I did have a low pass filter installed. My family still talks about watching JFK on TV when he said: "My fellow Americans... CQ 15.... CQ 15." Rich
| Top |
Peter Bertini
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Thu 21, 2011 4:24 pm |
| Moderator |
If Mike does get a HT-32 (and I'm doing my best to spend his money  } it has aux. relay contacts on the rear 11 pin connector for RX muting. Pete
| Top |
Mikeinkcmo
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Thu 21, 2011 5:11 pm |
| Top |
Peter Bertini
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Thu 21, 2011 5:38 pm |
| Moderator |
duplicate, reposted instead of edited.
| Top |
Peter Bertini
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Thu 21, 2011 5:42 pm |
| Moderator |
It might be easier to lift the ground return on the bias pot in the HT-32 to bias the finals into cut-off. But.... I vaguely remember that the high B+ on the 6146s soared to uncomfortably high levels when the supply was unloaded--especially at higher line voltages.
I think that's what scared me off on doing any mods of that nature. HT-37 and HT-32 are of the same ilk... HT-37 cut back on the frills (cast metal bezels, etc.) and dropped the crystal filters for a phasing type SSB generator. Otherwise the electronics are pretty much the same.... HT-32 is prettier and matches the SX-101 series, but lacks 160 meters.
Pete
| Top |
Burnt Fingers
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Thu 21, 2011 6:02 pm |
Joined: Oct Sat 20, 2007 3:36 am Posts: 13596 Location: New Hampshire
I have two Johnsons, one each on a Viking I and II with and without an amp. There are also two B&W's that handle the HT-9's and whatever else I want to use and Im looking for more. Trying to get rid of all the Dow Keys. Since I operate only with headphones muting isnt an issue and no receiver front end coils have been harmed performing these tests The vintage SSB stations each feed a NCL-2000 which have built in relays and inputs for seperate TX/RX there is no problem there either. Carl
| Top |
Peter Bertini
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Thu 21, 2011 6:49 pm |
| Moderator |
I'm sure I'll gravitate to T-R switches on the two B&W 5100s that are sitting on the shack floor waiting for me to finish the new shack operating table. Those Johnson TR switches have gone out of sight price wise. But I keep watching for one that slips by for under 50 bucks.
Pete
| Top |
BillJ
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Thu 21, 2011 9:54 pm |
Johnson also made a "companion" the Signal Sentry. It handled the audio muting and generated a separate "artificial" cw note for monitoring. I used the pair for many years with a Heath Apache/HQ170. Still have them! The red pin jack on the T/R switch feeds the Sentry.
| Top |
Mikeinkcmo
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Thu 21, 2011 10:32 pm |
Pete, T2 appears to be a powdered Iron(black) core about an inch and an eighth O.D., the coil is single layer 15T with the tap at 3T, #26 enameled wire. Should I be expecting progress "pics and story at ten"?  Bill, I'm going to run the "probe" to my gates modulation monitor, and from there to the bench oscilloscope.
| Top |
Peter Bertini
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Thu 21, 2011 10:37 pm |
| Moderator |
Hi Bill
That photo looks very familar. Is it featured on a website you own?
Mike, the SX-101A is on the floor next to the bench; I've had a continuous stream of outside work that's been keeping me from my own projects. But, if I can tempt you into spending more money you can bet I'll be posting photos of the SX-101 and HT-32 when they are finally together in the cherry wood cabinet, LOL. Seriously, I'm getting anxious to see them both up and running.
Pete
| Top |
KB8CWB
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Thu 21, 2011 10:43 pm |
| Member |
Joined: Aug Mon 24, 2009 10:26 pm Posts: 914 Location: West Salem, OH
Peter Bertini wrote: Quote: But I keep watching for one that slips by for under 50 bucks. Under $50?!  I think I might still have one in my pile unless I tossed it. I was told it was working but maybe like 20 years ago I hacked the power cord off as I was going to toss it then. Needed the cord for something can't remember. Go figure they are worth a bundle now! Bill P.S. Come to think of it I think I remember seeing the silly thing when I found that meter for graylox.... Maybe I can find it a home..
| Top |
Peter Bertini
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Fri 22, 2011 12:31 am |
| Moderator |
KB8CWB wrote: Peter Bertini wrote: Quote: But I keep watching for one that slips by for under 50 bucks. Under $50?!  I think I might still have one in my pile unless I tossed it. I was told it was working but maybe like 20 years ago I hacked the power cord off as I was going to toss it then. Needed the cord for something can't remember. Go figure they are worth a bundle now! Bill P.S. Come to think of it I think I remember seeing the silly thing when I found that meter for graylox.... Maybe I can find it a home.. Let me know what you want for it if you decide find it a home. Pete
| Top |
Jthorusen
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Sat 23, 2011 2:27 am |
Joined: Nov Mon 02, 2009 7:01 am Posts: 45 Location: Lancaster, CA
Greetings, All!
It would seem that most of you appear to be missing the point.... the Johnson electronic TR switch is intended for a specific application.... namely fast break-in CW. You are supposed to hear yourself (side tone) but the idea is that any other station's CW signal can be heard in the gaps between your characters, or even between your dots and dashes. The receivers of the day were operated with no AGC (volume control set to max and volume controlled with the RF gain pot) when receiving CW (BFO in use) so receiver recovery time was not an issue. There is absolutely no point in using an electronic TR switch for any other mode of operation, as conventional TR schemes are superior for voice work.
73, Jim T. KB6GM
| Top |
manualman
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Sat 23, 2011 4:15 am |
| Member |
Joined: Nov Sat 07, 2009 11:37 pm Posts: 423 Location: NJ
In the receive mode, the TR switch also acts as a RF amplifier raising the noise level of the receiver. If you're listening to a strong AM signal between the frequency operating range of the TR switch, it can add distortion to the signal. Personally, a good old fashion relay, works a lot better, and can have additional contacts to do additional switching if needed.
Pete
| Top |
Peter Bertini
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Sat 23, 2011 5:12 am |
| Moderator |
The HT-32 has been modified for semi-break in CW. I'll take a small trade-off on the receiver rather than hearing a Dow Key clanking its brains out between characters. The way the HT-32 is designed, spare contacts on the internal relay are used to key the antenna relay. The transmitter is at full RF power almost instantaneously when the CW key is closed, and the antenna relay ends up hot switching RF because the sequencing is wrong and the mechanical delays.
For the B&W 5100 TXs on phone, it might be a valid point that a T-R switch won't offer much over an external relay.
Pete
| Top |
Tubenut
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Sat 23, 2011 7:45 am |
Joined: Oct Sun 11, 2009 10:06 am Posts: 1441 Location: British Columbia
Cool little electronic t/r switch Mike. I used to build those right into some sets. I just finished a t/r box for a fellow ham. Very indepth, long term project. (glad its over )
| Top |
Burnt Fingers
Post subject: Re: E.F. Johnson electronic TR Switch Posted: Jul Sat 23, 2011 2:40 pm |
In the 50-60's many used them on AM with no problem and on 10-20M the slight bit of preamp gain was a big help on just about anything using octal tubes or an otherwise basic front end.
With the Dow Key noise and often sticking receive side isolating contact it was a pleasure to get rid of them.
The B&W 381 series had a band switch and later versions had a tuning control which both improved image rejection a bit and could be detuned as a gain control on the lower bands. Mine are both the 381C.
| Top |
