It is currently Jan Mon 22, 2018 1:30 am
 Post subject: hallicrafters SX-110
PostPosted: Sep Thu 29, 2011 10:06 pm
A few years ago, I bought a Hallicrafters SX-110 at a local meet. The seller told me it was working last time he used it.
As it turns out, I put it in the closet and forgot about it. I recently found it and want to start using it .
So heres the question: What kind of basic restoration should I do on it just in order to be able to use it? I'm not looking to do a full resto, as I'm not a genius with electronics, but I can replace basic parts and can handle a soldering iron.
Would replacing all the tubes be a good start?
Your thoughts are appreciated!
 Post subject: Re: hallicrafters SX-110
PostPosted: Sep Thu 29, 2011 11:18 pm
No need to replace the tubes unless they are proven bad . . . they are probably OK. What needs to be replaced are the paper and electrolytic capacitors.
What happens under the chassis stays under the chassis.
PostPosted: Sep Fri 30, 2011 1:10 am
Some people like to first test the power transformer then go ahead and test tubes, change caps, test resistors. When completed they deal with what else might be wrong.
I like to test the power transformer, test for obvious B+ shorts, then bring the radio up with a variac to get an idea what I should do next.
PostPosted: Sep Fri 30, 2011 4:35 pm
Thanks guys.
Yea, I figured its going to be the caps that need replacement. I'll have to get the SAMS guide for that box.
PostPosted: Sep Fri 30, 2011 4:56 pm
You can get a free manual download for the SX-110 here:
http://bama.edebris.com/manuals/hallicra/sx110/
PostPosted: Sep Fri 30, 2011 8:38 pm
Thank you very much for posting that.
Guys, question:
When replacing the caps, how many do you typically do at a time? Do you do, say 5, then power the unit on and see if there are any problems?
PostPosted: Oct Sat 01, 2011 4:10 pm
Ive been doing these repairs since the 60's and still do only 3-4 at a time and also check the asssociated resistors.
Post New Topic Post Reply  [ 7 posts ]  Moderator: Sandy
Users browsing this forum: Norm Johnson and 14 guests
