Page 1 of 1
[ 9 posts ] |
| Author |
markbark
Post subject: Info needed on Hammerlund 160 Posted: Jan Tue 24, 2012 9:01 pm |
| Member |
Thanks people, Does anyone know a replacement for the s-meter, either original or not, for my 160? I can't get mine to move except when I juggle the AVC switch in which case it deflects a hair. What is the best source for tubes? Thanks
| Top |
Johnnysan
Post subject: Re: Info needed on Hammerlund 160 Posted: Jan Tue 24, 2012 11:26 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 11441 Location: Albuquerque, NM 87123
Is the meter really bad? I would test it with an ohmmeter and at least 27k in series to see if there is any deflection.
| Top |
manualman
Post subject: Re: Info needed on Hammerlund 160 Posted: Jan Wed 25, 2012 4:41 am |
| Member |
Joined: Nov Sat 07, 2009 11:37 pm Posts: 387 Location: NJ
I believe the meter movement and the meter mounting center-to center distances and the large cutout are the same as used on the HQ-170 and HQ-180 series of receivers.
Pete
| Top |
w3jn
Post subject: Re: Info needed on Hammerlund 160 Posted: Jan Wed 25, 2012 5:43 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2719 Location: Athens, Greece
If it deflects a bit it's probably not bad. Could be mechanically binding, but most likely, an issue with the S-meter sensitivity and/or zero set pots, or the cathode circuits of V5 and V6 (including the sensitivity control).
| Top |
AB
Post subject: Re: Info needed on Hammerlund 160 Posted: Jan Wed 25, 2012 2:47 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 388 Location: far western end of Maryland
1) the s meter on my 160 stopped working a while back; turned out it was the 1st IF tube . The receiver worked OK otherwise but something was messed up enough with the tube that the s meter did not work until the tube was replaced.
2) Hopefully you have the manual for the 160, but as the manual points out the S meter only works with the AVC "ON"
3) Also, as others noted if the meter deflects at all it's likely OK. Also see the manual for the s meter pots adjustments
Andy
| Top |
quadlibet2001
Post subject: Re: Info needed on Hammerlund 160 Posted: Jan Wed 25, 2012 5:48 pm |
| Member |
Joined: Feb Tue 02, 2010 1:46 pm Posts: 1048 Location: VA, 24019
I don't know the tube layout of the 160, but I swapped 12AU7s in my 180A and there was a difference in S-meter behavior.
| Top |
markbark
Post subject: Re: Info needed on Hammerlund 160 Posted: Jan Wed 25, 2012 6:17 pm |
| Member |
thanks guys much appreciated, will report back after replacing tube. mark
| Top |
w3jn
Post subject: Re: Info needed on Hammerlund 160 Posted: Jan Thu 26, 2012 4:55 am |
Your FIRST step should be the zero set and sensitivity adjust pots. If the meter is resting on its left peg, the zero adjust pot needs to be adjusted - you should be able to adjust it throughout its full range with that pot. The pot could be dirty or intermittent - crank it thru its range a few times and report back what happens to the meter.
| Top |
Eickerman
Post subject: Re: Info needed on Hammerlund 160 Posted: Jan Thu 26, 2012 11:15 pm |
| Member |
AB wrote: 2) Hopefully you have the manual for the 160, but as the manual points out the S meter only works with the AVC "ON" That's true even though all the circuitry was there to allow AVC and S-Meter operation on SSB-CW just like the HQ-180. It was a design choice to disable it. viewtopic.php?f=5&t=182973&p=1524435#p1524435Curtis Eickerman
_________________ http://curtiseickerman.weebly.com
| Top |
Page 1 of 1
[ 9 posts ] |
Moderator: Sandy |
Users browsing this forum: No registered users and 5 guests |
