It is currently May Tue 21, 2013 8:20 am
 Post subject: National 183D Restoration Question(s)
PostPosted: Apr Fri 20, 2012 8:09 pm
I have a physically nice 183D that I'm repairing. Half the capacitors have been replaced previously with "Orange Drop" capacitors, 15 caps remain.....mainly .1uF's, .01uF's and .05uF's. Should I replace these caps just as a upgrade?
I've read that the Power Xfmr is prone to fail. Was their a later Power Xfmer installed to correct this??? A phyisical marking or date code from the factory in later units?
Thanks for looking
Bill KB9IV
 Post subject: Re: National 183D Restoration Question(s)
PostPosted: Apr Fri 20, 2012 10:11 pm
I would replace all original paper and electrolytic caps if the radio is to be used for more than a few minutes.
I don't know anything about an upgrade transformer, but I would consider it unlikely that National engineers would use a marginal transformer. Perhaps it was a flaw in transformer design, but that would be the mistake of the manufacturer, not National.
PostPosted: Apr Sun 22, 2012 3:44 pm
National did use marginal power transformers in those sets originally, no one knows the reason, but they are often found with the transformer bad. There is an updated replacement to correct the problem.
Yes, you should replace every paper capacitor and electrolytic, they were bad decades ago.
PostPosted: Apr Sun 22, 2012 3:55 pm
See the other 183D thread just below this for explanations.
Post New Topic Post Reply  [ 4 posts ]  Moderator: Sandy
