It is currently May Sat 25, 2013 1:34 pm
 Post subject: JOHNSON 223 TRANSCEIVER
PostPosted: Apr Wed 25, 2012 6:00 am
Hi All,
Is this this the proper place to discuss my Johnson 223 C.B. Boat anchor ???
There is so much knowledge here, I hope I can avail of it...
Thank You All ... Freddbro... N3JFN... :oops:
 Post subject: Re: JOHNSON 223 TRANSCEIVER
PostPosted: Apr Wed 25, 2012 1:28 pm
It's OK to talk vintage CB here. What would you like to discuss?
PostPosted: Apr Thu 26, 2012 6:04 am
Dear David & Group, My Johnson 223 CB uses about 13 Xystls to generate 23 channels
I guess the mix among themselfes to generate 23 channels ..
How can I get up to 40 channels?? " VFO" ?? Will the "VFO" be both Trans. & Rec ??
Thats all I can think of.. Any Suggestions ?? Thank You... freddbro :?
PostPosted: May Tue 01, 2012 8:32 am
very dificult to do.
The frecuencys are generated by mixing 2 cuarz for each, so you need to use some spectial switch to combine them.
If you try to use more cuarz to get more channels, you need to build another spectial switch.
it´s more eassy and cheap to pick a new cb radio
Post New Topic Post Reply  [ 4 posts ]  Moderator: Sandy
