It is currently Apr Sun 22, 2018 1:55 am
 Post subject: Hallicrafters SX-28A question
PostPosted: Dec Thu 29, 2016 5:39 pm
On my SX-28A there's a screw through the front panel held by a hex nut behind the panel adjacent to the 10 o'clock position of the main tuning knob logging scale. The screw doesn't fasten anything to the panel so I'm wondering what it's purpose is?
I also notice that images posted online show that some sets have the screw while others don't... Is it only found on later 28s or 28As?
 Post subject: Re: Hallicrafters SX-28A question
PostPosted: Dec Fri 30, 2016 4:12 am
My very early -28, and my very late Navy -28 do not have this screw, or a hole for it.
73
Chuck
PostPosted: Dec Fri 30, 2016 5:05 am
My early 28A doesn't have that screw either. No idea what it might be for.
Bold text & pics are usually links.
PostPosted: Dec Fri 30, 2016 12:50 pm
I'm confused but that's not new. Can you post a pic of what you're talking about. I've got a bunch of 28's of all vintages in storage and will take a look this afternoon.
"The first speech censured, the first thought forbidden . . . chains us all irrevocably."
PostPosted: Dec Fri 30, 2016 3:06 pm
Mine's on the bench upside down with the panel facing away for RF rebuild so it's not practical to get a picture of the front right now but here are a few links that have the screw:
http://www.cryptomuseum.com/df/sx28/img/300413/007/full.jpg
http://i.imgur.com/vcwDz.jpg?1
http://www.radioblvd.com/SX-28/grr2&pan1.jpg
Look straight down from the center of the meter to the edge of the tuning log. It's roughly across the log scale from the right hand panel mounting screw.
PostPosted: Dec Fri 30, 2016 7:32 pm
Here's a straight-on view. Photo was labelled "SX-28AU". Sorry I can't credit online source.
-Chuck
PostPosted: Dec Fri 30, 2016 7:40 pm
I have a couple of AU in storage, I'll see if they have the screw and if anything is attached.
PostPosted: Dec Fri 30, 2016 7:58 pm
You probable already did this, but the original sx-28 and 28A manuals don't show a screw in that position.
PostPosted: Dec Fri 30, 2016 8:16 pm
Okay, at the storage unit. 9 of 9 SX28's/28A's have no screw and no hole for a screw. Both SX28AU's have the hole and the screw, Without bringing one home and taking the bottom panel off I can't tell where the screw goes or what it does but I can see a screw fastened with a nut that exits the rear of the gear box that is in the same/similar position relative to the front panel. Not a lot of help yet, but when I can get the storage unit unpacked I may have an answer.
PostPosted: Dec Fri 30, 2016 10:33 pm
Thanks Jack. Don't unpack anything on account of my question. It's not that important.
I'm not familiar with the "AU" designation. Is that a later or military version of the 28A?
PostPosted: Dec Fri 30, 2016 11:12 pm
It's the dual voltage model with a switch on the to of the yransformer
PostPosted: Dec Sat 31, 2016 7:35 am
I have an early 1945 model--never modified. It has the screw with a nut in back that seems to do nothing?!?
Don F
PostPosted: Dec Sat 31, 2016 5:18 pm
This is from Radio Blvd............
Upper Panel to Cabinet mounting screws (flanking main tuning dial) are being used by SN H-124230 (12/40) - Interestingly, even the earliest cabinets always did have the two tabs to accept these screws however the front panel was not drilled for these two screws until around 12/40.
Perhaps this is an answer to the question?
http://www.radioblvd.com/SX28Notes.html
Todd
PostPosted: Dec Sat 31, 2016 5:52 pm
Todd
I believe that statement addressed the screws on either side of the tuning dial escutcheon that fastened the top of the front panel to the cabinet.
PostPosted: Jan Fri 06, 2017 2:24 pm
Just picked up another 28A last night and it has the screw. Will start teardown tonight and will report if there is any
thing attached.
PostPosted: Jan Tue 10, 2017 5:21 am
Be sure to tell Radio Boulevard the serial numbers on your 28s;
PostPosted: Jan Thu 12, 2017 4:25 pm
My 28A has one as well. Was never able to track down any info either, but speculate that it may be related to left over WWII panels that may have had a lug or terminal strip mounted back there for some military contract like diversity, etc. Again - it's just a guess. Hallicrafters, National, and probably other manufacturers were known for using up as much of their WWII stock as possible on postwar gear. I've seen numerous postwar civilian HROs sporting an IF or two with MFP coating, for example, while other cans are bare aluminum.
RCA did this on a prewar receiver I have simply for symmetry. Added a screw and dress washer with no other purpose. Of the 3-4 others I've seen, each had the same. They also added a dummy tuning eye bezel with a lens and bulb behind it that lights in standby.
Post New Topic Post Reply  [ 17 posts ]  Moderator: Sandy
Users browsing this forum: joelandjoyce, Tim Tress and 5 guests
cron
