It is currently Oct Sat 20, 2018 5:09 am
 Post subject: National NC-100X speaker enclosure
PostPosted: Nov Thu 23, 2017 4:46 pm
Thanks to all of the help that I have received from people on this site, my 1936 National NC-100X is now restored and working. When I got it, it was in pretty bad shape and did not have the accompanying speaker. I used an old Philco EM speaker and a Hammond output transformer, and they work well. Now I need a box for the speaker. Does anyone have a lead on where I might get an original? I can build something if necessary but it would be nice to have an original, if this 12-inch Philco would fit inside it. Or if the original had a working speaker in it.
Thanks!
73 Charles W4KEP bostian@vt.edu
 Post subject: Re: National NC-100X speaker enclosure
PostPosted: Nov Fri 24, 2017 6:11 pm
Pretty sure the original was a 10". National also made an 8" and 10" pm spkr (in cabinets) but these are mostly use for the HRO series. They don't require a field coil and have a single output tube.
Terry N3GTE
PostPosted: Nov Fri 24, 2017 9:45 pm
National sold the DCS-8 and DCS-10 cabinets for the 8 and 10 inch speakers (the 8" came with the battery version of the NC-100) and these cabinets matched the NC-100. They also sold the set with a Rola G12 speaker but I have never seen that setup or what cabinet, if any, was included.
Since the NC-100 itself is only 9" tall I suspect the Rola 12" was intended for mounting in a custom floor standing cabinet like that seen with some of the RCA, Hammarlund, and Hallicrafters receivers of the 1930s.
Rodger WQ9E
PostPosted: Nov Sat 25, 2017 3:24 am
Charles,
For what it might be worth, my NC-100 came with a National speaker. It is a 10” in a black steel cabinet 12-1/8”W x 10-7/8”T x 10”Dp. The steel cabinet has a wooden box, made from 1/2” stock, finger jointed together, which fits tightly into the steel cabinet. It is painted black crinkle to match the radio. I don’t know if it would have been used with the NC-100X. It uses a field coil 10” driver. There is a simple round opening with grill cloth attached to the internal wooden box.
Chris
N9WHH
PostPosted: Nov Sat 25, 2017 4:51 am
Looks like this except for the grille cloth.
https://www.flickr.com/photos/42774321@ ... ateposted/
Terry N3GTE
PostPosted: Nov Sat 25, 2017 6:14 am
Well, at the risk of hijacking this thread, does anyone know what this National speaker was intended for originally? Any transformers were not still installed in it but there is a Rola 8" (I think) cone in there. There was a transformer rather crudely hanging by its leads inside with a Navy type number that translates to something for the RAS, but I thought the RAS had a rack mount speaker nothing like this.
WB6NVH
http://www.wb6nvh.com
PostPosted: Nov Sat 25, 2017 1:23 pm
For those interested in finding out which speakers went with their receiver, HERE IS A LINK to a list of the more popular models.
PostPosted: Dec Fri 01, 2017 1:54 pm
If you have the room, why not build or have built an open back speaker box for the speaker and make it large enough for the receiver to sit on?
I did that for my R-390 using a 12" field coil speaker with a separate audio amp in the speaker box. Sounds great.
Post New Topic Post Reply  [ 8 posts ]  Moderator: Sandy
cron
