It is currently May Mon 20, 2013 6:44 pm
 Post subject: philco 40-150 power transformer replacement
PostPosted: Apr Fri 06, 2012 10:13 pm
My 40-150 has an open primary winding need to know what replacement transformer i need to use
 Post subject: Re: philco 40-150 power transformer replacement
PostPosted: Apr Fri 06, 2012 10:23 pm
Hi
Philco 40-150 power transformer needs two secondaries, 6.3 volts @ 3 amps and around 270-0-270 volts @ 90 ma. To figure current add up all tube and lamp filaments, just under 3 amps. For secondary current on high voltage I use 90 ma when a radio has push-pull output tubes (#41's). In this radio it could be a little lower since B+ voltage is fairly low.
http://www.nostalgiaair.org/PagesByMode ... 013331.pdf
You can check here for a replacement:
http://www.oldradioparts.com/2a23efl.txt
A modern transformer can be purchased from AES, http://www.tubesandmore.com or Radio Daze, http://www.radiodaze.com .
Post New Topic Post Reply  [ 2 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: JerryHawthorne, Oldbear and 7 guests
