Page 1 of 1
[ 6 posts ] |
| Author |
hotdogx
Post subject: 4-in-1 Electrolytic Capacitor? Posted: May Sat 05, 2012 3:36 pm |
I am restoring a Knight Kit Star Roamer. It uses a unique 4-in-1 electrolytic capacitor (brand name Lil J) that has values of 30-30-30-50 mf. Before I replace it with 4 individual electrolytic caps, is anyone aware of a modern 4-in-1 replacement for this? I've done a bit of web research and it appears that 4-in-1 electrolytics are no longer made.
_________________ Al Clark
| Top |
Dave Mc
Post subject: Re: 4-in-1 Electrolytic Capacitor? Posted: May Sat 05, 2012 3:46 pm |
| Member |
Joined: Jul Sun 09, 2006 5:18 pm Posts: 1260 Location: Dandridge, TN
CE Manufacturing makes new twist lock multi-section capacitors using the original machinery (expensive). I see that Antique Electronic Supply sells them, but I do not see the value you need. I would simply open it up and restuff it using 33 and 47mfd 160 volt radial lead electrolytics. If there is not room for all 4, one or more can be tacked in somewhere. There are methods for restuffing documented on the forum. Search using GOOGLE, site:antiqueradios.com
_________________ Dave McClellan, W6SQV(/4) http://mcclellans.com/RadiosPage9-2010.htm
| Top |
Art Hoch
Post subject: Re: 4-in-1 Electrolytic Capacitor? Posted: May Mon 07, 2012 3:06 am |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2361 Location: McPherson, Kansas
If you use the smaller, flat, polyester film green-colored types of caps, you should have room for 4 in the original can.
| Top |
BikenSwim
Post subject: Re: 4-in-1 Electrolytic Capacitor? Posted: May Mon 07, 2012 5:01 am |
Joined: Oct Wed 14, 2009 6:36 am Posts: 3029 Location: New York USA
If that is a cardboard cylinder with wires, AES has the triple capacitor, and the fourth capacitor may be a small cathode bypass that can be hidden by the output tube, no one will notice. Don
| Top |
Dave Mc
Post subject: Re: 4-in-1 Electrolytic Capacitor? Posted: May Mon 07, 2012 11:45 am |
| Member |
Art Hoch wrote: If you use the smaller, flat, polyester film green-colored types of caps, you should have room for 4 in the original can. I think they need to be electrolytic types. I have never seen a film capacitor with that high a capacitance. But, I have not seen everything either!
| Top |
Art Hoch
Post subject: Re: 4-in-1 Electrolytic Capacitor? Posted: May Mon 07, 2012 10:52 pm |
| Member |
Dave Mc wrote: Art Hoch wrote: If you use the smaller, flat, polyester film green-colored types of caps, you should have room for 4 in the original can. I think they need to be electrolytic types. I have never seen a film capacitor with that high a capacitance. But, I have not seen everything either! *********************** Of course; I didn't pay attention to the values. Never seen that big of a "greenie" either. Good luck.
| Top |
