Joined: Jan Thu 01, 1970 1:00 am Posts: 5255 Location: S. Dartmouth MA 02748-1225 USA
I re-wound an oscillator coil for a Grunow. I dunked it in melted bees wax and pulled a vacuum over it. After much bubbling the vacuum was released and the coil allowed to cool. When the coil was cold it was dipped again to get a thick coating, worked perfectly...
_________________ "Don't find fault, find a remedy"
Joined: Jan Thu 01, 1970 1:00 am Posts: 28944 Location: Livermore, CA
Chas went through an interesting procedure. A lot of us can't draw a vacuum etc. His coil worked perfectly but it will still operate without the wax coating.
Joined: Jan Thu 01, 1970 1:00 am Posts: 7456 Location: Toledo, Ohio
Thanks for the replies. I was tossing around the idea of using parrafin but now I see it has a lower melting point than beeswax (120 compared to 140) so I'll coat it with the bees.
_________________ Jim
"AC volts and DC volts and little lamps and lities..."
If the coil is placed in the cup with melted bees wax and left to soak for 1/2 an hour or so, most of the moisture should be driven off without using a vacuum. Let the coil cool then re-dip, quickly, to get the thick surface like a factory job
