| Author |
radiopicker
Post subject: Re: Need help aligning my Zenith -- I hate alignments Posted: Jul Thu 05, 2012 5:38 pm |
| Member |
Joined: Aug Thu 18, 2011 4:48 am Posts: 2499 Location: Stamford, NY
Yes this is a before picture, every single resistor and capacitor has been replaced, every one. I just haven't taken any new photos yet. Any ideas on trimmer "L"? I'm assuming the coil on the back side of the chassis is the wave trap, right?
_________________ Vincent
| Top |
codefox
Post subject: Re: Need help aligning my Zenith -- I hate alignments Posted: Jul Thu 05, 2012 6:28 pm |
Seems one of these is for obsolete police band which you can forget about, other one to peak SW at 16.5 MHZ which you should be able to achieve with most signal generators, or a high harmonic modulated. Unless these caps are filfthy or shorted best leave alone. If you decide to clean them, count turns accurately to close completely, open
| Top |
radiopicker
Post subject: Re: Need help aligning my Zenith -- I hate alignments Posted: Jul Thu 05, 2012 6:39 pm |
| Member |
The police trimmer is N which I have identified, I'll leave that be. All trimmers are accounted for above chassis and on rear except for "L" which is under the chassis. Trouble is that there are 4 trimmers under there and I don't know which one is "L" to adjust for 16500 SW. The uppermost trimmer you see circled in the picture is the one I originally thought was "L" and fiddled with. I think I put it back to where it should be, I have it in the same position, but I'm not positive if it should be backed out or in one whole turn. Right now I think it's not too tight and not too loose, so I think that's the way it is  , but again, not sure if that's "L" or not.
| Top |
Brett_Buck
Post subject: Re: Need help aligning my Zenith -- I hate alignments Posted: Jul Thu 05, 2012 7:57 pm |
Joined: Aug Wed 24, 2011 4:35 am Posts: 1272 Location: Sunnyvale CA
codefox wrote: Seems one of these is for obsolete police band which you can forget about, other one to peak SW at 16.5 MHZ which you should be able to achieve with most signal generators, or a high harmonic modulated. Unless these caps are filfthy or shorted best leave alone. If you decide to clean them, count turns accurately to close completely, open If it was me, I would suggest going ahead and doing the police band alignment. I have noticed several times that the police band adjustments on various Zenith radios (8s661, for example) altered the BC band slightly. It only takes few minutes . Brett
| Top |
Tube Radio
Post subject: Re: Need help aligning my Zenith -- I hate alignments Posted: Jul Thu 05, 2012 8:18 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7883 Location: Warner Robins, GA
Yes best to align the police band.
| Top |
StrombergMike
Post subject: Re: Need help aligning my Zenith -- I hate alignments Posted: Jul Thu 05, 2012 8:26 pm |
| Member |
Joined: Aug Wed 31, 2011 4:51 pm Posts: 224 Location: Blk Mtn, NC
radiopicker wrote: :shock: You guys are gonna kill me. I did a second BCB alignment just to confirm and fine tune. I was happy with the location of my SSTRAN station on the dial. I got the IFs peaked but as far as "alignment" SSTRAN station comes in at 1060KC and weaker at 1500KC. A) way off B) Why is there a duplicate station (image)?
1500KC-1060KC=440KC, could this be the 455KC local IF frequency? Thanks Mike
_________________ Radiola 17/100 Cossor 3468 S'tone 6130 S'berg 535M GE 417A T'tone D1952 Phil. 118H Delmonico PB-741
| Top |
radiopicker
Post subject: Re: Need help aligning my Zenith -- I hate alignments Posted: Jul Thu 05, 2012 9:32 pm |
| Member |
Okay will do, might as well! Thanks for letting me know. Does anyone out there have a clue as to which trimmer is "L"? I don't know how to figure this out.
| Top |
Who is online |
Users browsing this forum: Brett_Buck and 6 guests |
