Post subject: Atwater Kent 2nd AF Input Transformer
Posted: Aug Sat 04, 2012 2:09 am
Joined: Aug Sat 04, 2012 1:56 am Posts: 3 Location: Jacksonville, Fl.
Hi everyone, I have a model 67 Battery model Atwater Kent with a bad transformer. I have melted out all the tar that was in the can and removed the transformer.. I couldn't get a reading on any of the leads. Luckily, the nostalgia air scans of rider's has the impedance written on the diagram (attached.) It has an 1,100 ohm primary and a center-tapped 7,000 ohm secondary. I measured the enameled wire's diameter at 39awg (.8-.9mm) if that helps. I was thinking of winding another coil myself if I can't find any replacements.
Does anybody have an idea where I can find a replacement?
