It is currently Jan Sat 20, 2018 6:21 pm
 Post subject: Can an AK resistor be repaired?
PostPosted: Jun Sun 18, 2017 4:24 pm
Anybody had any luck fixing one of these?
 Post subject: Re: Can an AK resistor be repaired?
PostPosted: Jun Sun 18, 2017 4:56 pm
I think any repair is highly unlikely.
Those "flexible resistors" were used because low-value carbon comps were not available.
There's nothing particularly special about them. Power dissipation was low to moderate.
The issue with their manufacture was that resistance wire cannot be soldered.
Consequently the ends had solderable ferrules that were crimped onto the wire.
I usually disconnect one end, leaving the item in place for cosmetics.
Then put a modern resistor at one end and run a wire to the other end.
73 de Leigh W3NLB
PostPosted: Jun Sun 18, 2017 9:30 pm
Leigh, thanks for this information and others that you post. I learn a lot from them. Keep up the good work.
Ed
The more I know about women, the better I like my radios and TVs.
PostPosted: Jun Sun 18, 2017 11:15 pm
Thanks, Ed. Happy to help.
73 de Leigh W3NLB
PostPosted: Jun Mon 19, 2017 4:12 pm
Here is an AK flexible resistor I was able to rebuild. It is from an AK 155 (19 ohms pilot lamp shunt). I used the original resistance wire (which was broken away from the terminal at one end). I ground off the brass rivets on both ends, then reattached the resistance wire using 4-40 brass hardware and small washers. The insulator is a piece of small spaghetti tubing. The ends were insulated using a couple of layers of shrink tubing. Obviously the order of reassembly is critical. It works and the resistance is within 10%.
Dave McClellan, W6SQV(/4)
http://mcclellans.com/RadiosPage2015.htm
PostPosted: Jun Mon 19, 2017 5:42 pm
Very nice, Dave.
73 de Leigh W3NLB
PostPosted: Jun Mon 19, 2017 7:31 pm
http://www.russoldradios.com/blog/atwater-kent-559n
http://russoldradios.com/
PostPosted: Jun Mon 19, 2017 8:52 pm
Great job on that 559, Russ.
73 de Leigh W3NLB
PostPosted: Jun Mon 19, 2017 8:56 pm
Thanks. I like it.
PostPosted: Jun Wed 21, 2017 7:11 pm
Nice work, thanks for the information
Post New Topic Post Reply  [ 10 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: egg, Google Adsense [Bot], hartleymanages, nwsalmon, skylerca and 17 guests
