It is currently Feb Tue 19, 2019 1:16 am
 Post subject: JVC RC-s5jw boom box
PostPosted: Dec Tue 04, 2018 4:49 am
Hi. Hoping someone can help with my issue.
I opened up my boom box and accidentally pulled the antenna cord from a post on the board and can't figure out how to put it back. The unit works great, but without the antenna, the radio doesn't. I don't have a schematic but can post a photo if that helps.
thank you
 Post subject: Re: JVC RC-s5jw boom box
PostPosted: Dec Tue 04, 2018 2:55 pm
Cord ? Do you mean wire ? If so solder it back to the pin on the board. Or post a picture.
PostPosted: Dec Tue 04, 2018 5:36 pm
You can post photos as attachments straight out of the chute. No need to wait 24Hrs.
The skinny: viewtopic.php?p=2717120#p2717120
https://www.radiomuseum.org/r/jvc_compa ... _s5jw.html
I have an almost identical JVC from 1980, albeit at a different location!
PostPosted: Dec Wed 05, 2018 2:42 am
Thanks for helping me with this. I got one step closer. I did figure out where the wire goes ...however, I must have broken the end because I can't push it back in. Do I need a new connector? Can I solder it back in (doesn't appear that it will stay due to the shape). Here are some photos that I hope you can see. Yes, when I touch the connector to the port, the radio antenna works... the port says "Ant to Rod" so once I found that, I was a little closer. Thanks again!
PostPosted: Dec Wed 05, 2018 5:07 am
That is a spade connector, and yes... it is broken-off!
I had a look at the schematic for my model JVC RC-656L/LB and there is a connector (of sorts) shown.
You could solder a short piece of insulated wire to both.
I will have a look at mine tomorrow, and report back... :)
Edit: To leave it detachable in the future, pull that terminal apart with a pair of pliers (bottom photo).
Connect (crimp tightly with pliers) a new terminal to short piece of insulated wire, and solder the bare wire end to your connector.
Electrical spade connectors at Walmart...
https://www.walmart.com/c/ep/electrical ... connectors
Any Auto-parts store will also have them.
PostPosted: Dec Thu 06, 2018 10:42 pm
wow. thank you but darn. I think that is above me. If you ever feel like making a video, please do : )
I will let you know how I do.
Thanks so much for your help.
I really want to learn this!
PostPosted: Dec Thu 06, 2018 11:27 pm
You will have to find someone to help you.
It's a five minute fix!
Edit: Post you location - via user control panel - profile.
If you find a radio-club nearby, they will show how to solder... and more!
PostPosted: Dec Thu 06, 2018 11:33 pm
Hope so. Would that just be any electrical guy or does it have to be an electronics person?
PostPosted: Dec Thu 06, 2018 11:38 pm
Any tinkerer in the neighborhood should do.
PostPosted: Dec Thu 06, 2018 11:51 pm
okie dokie ...lol
Thank you!
PostPosted: Dec Fri 07, 2018 12:19 am
can I ask you one more question. I have a toshiba table radio (11H-540F) that I believe needs an FM antenna.
AM works great but nothing FM. Is that the problem, I need some kind of antenna? If so, Can you suggest one?
thank you : )
PostPosted: Dec Fri 07, 2018 12:44 am
If you remove that connection to the power lead, you can use an FM indoor dipole as shown in the small diagram (FM ANTENNA).
You can purchase them, ready-made...
https://www.ebay.com/sch/i.html?_from=R ... le+Antenna
or, just make you own with some cheap bell-wire. Run it along your baseboard.
Edit: it doesn't have to change direction at 72" (sooner if you like).
PostPosted: Dec Fri 07, 2018 12:52 am
Terrific! Thanks so much for your advice. I did find a tinkerer for my JVC issue that I am going to see on monday. I most definitely will watch the repair and learn from it!
Nice to meet you!
Really appreciate it!
PostPosted: Dec Mon 10, 2018 12:43 am
I want to thank you again. I found my local fixer-upper. He attached the wire exactly as you described. I'll be ready to give it a go myself next time!
PostPosted: Dec Mon 10, 2018 2:05 am
You're welcome... :)
oh... here's my radio cassette. It cost me about a week's wages in 1980 Lol
PostPosted: Dec Mon 10, 2018 2:26 am
beautiful! Looks better than brand new!
PostPosted: Dec Mon 10, 2018 2:35 am
My bad... That is an ebay image.
Mine is in somewhat similar condition albeit with two broken antennas.
Post New Topic Post Reply  [ 17 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: Als_Basement, vtRon and 19 guests
