It is currently Jun Wed 19, 2013 1:34 am
 Post subject: Rectifier suggestion
PostPosted: Apr Fri 27, 2012 9:57 pm
Model: Wega 110
I want to replace the EZ 80 tube with a rectifier.
How can this be done ?
I have a schematic but the forum does not allow me to attach in pdf fromat .
Thanks in advance
 Post subject: Re: Rectifier suggestion
PostPosted: Apr Fri 27, 2012 11:27 pm
Pair of 1N4007 diodes. Take the leads from pins 1 and 7 of the rectifier socket (plates) and move them to the anode (non-band) end, one on each diode. The other end of the diodes - the cathode/banded end - should join together, and that junction point is where your unfiltered B+ will come from. This is Pin 3 on the socket. From there, run over to your first filter.
You may also need a dropping resistor...300 Ohm 5W, between the rectifier output and the first filter cap.
http://www.radiomuseum.org/tubes/tube_ez80.html
PostPosted: Apr Sat 28, 2012 5:34 am
[quote="jkoebel"]You may also need a dropping resistor...300 Ohm 5W, between the rectifier output and the first filter cap. [/]quote
What is the purpuse of the new dropping resister. I already have a 50 ohm 12 watt resister connected to pin 3.
M Khan
PostPosted: Apr Sat 28, 2012 6:49 am
when you change from a Tube rectifier, to silicon, the silicon is more efficient, so it drops only 1.5 volts while the tube rectifier could drop up to 30v so you may need to add a resistor to bring down your b+
add in the fact that older radios were made for 108 - 115 v and most power is not 120 - 125...
PostPosted: May Wed 02, 2012 1:55 am
Hi:
The diode jig worked just fine.
I am learning fast and every step gives me joy.
Thanks all.
M Khan
Users browsing this forum: Indytrains, KenK, Ruradio and 7 guests
