| Author |
populux
Post subject: Re: Do I need to be afraid to touch my Zenith 7L05 chassis? Posted: Jan Mon 16, 2012 5:42 am |
Wow, guys, thanks. It appears I've started a "hot" topic here.
I did get the Elements of Radio Servicing book and the schematics--thanks for those suggestions. Looking for an isolation transformer and in the meantime won't be plugging the chassis in anytime soon due to all these scary warnings. Good tips about keeping one hand away so as not to make a circuit and wearing rubber soles etc.
I am well aware of how little I know. That said, I do like just jumping in and seeing how far I can get. I know it will take awhile to get up to speed....
PS If there's anyone in the Boulder/Denver area who would be willing to show me a few tricks, that would be great. populux at gmail dot com
| Top |
jason1141
Post subject: Re: Do I need to be afraid to touch my Zenith 7L05 chassis? Posted: Jan Tue 17, 2012 11:38 am |
Joined: Dec Fri 16, 2011 12:49 am Posts: 90 Location: Columbus, Ohio
Although I can't add much to what these guy's have told you so far because I am new to the hobby also I will tell you that I did not take my time (I'm impatient) to learn all I needed before jumping in with both feet. I have made a ton of mistakes and have had to go back and learn the basic's anyway so I would have a slight idea of what they are talking about. Restoring these amazing radio's is harder/easier than I ever thought but the reward of seeing one and hearing one come alive is more than I ever thought. This site has helped me tremendously and will help you also. Take your time it will be worth the wait.
_________________ 101st Airborne 502nd Infantry....
| Top |
tubeAMP
Post subject: Re: Do I need to be afraid to touch my Zenith 7L05 chassis? Posted: Jan Tue 17, 2012 3:08 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2754 Location: Gainesville, Florida
| Top |
mikeg52
Post subject: Re: Do I need to be afraid to touch my Zenith 7L05 chassis? Posted: Jan Thu 19, 2012 5:50 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 611 Location: Marshall, Il. USA 62441
I agree with the educational issue. A member of my radio club has produces some very resaonably priced DVD's on radio restoration. Below is his contact information. Bret Menassa Bret's Old Radios P.O. Box 51671 Denton, TX 76206 Website: www.bretsoldradios.com Email: bretsoldradios@att.netFour part video series on repairing and restoring vintage radios Good luck! Mike
| Top |
tubeAMP
Post subject: Re: Do I need to be afraid to touch my Zenith 7L05 chassis? Posted: Jan Thu 19, 2012 1:57 pm |
hints and kinks forum has some great resources to start with. should be some 'sticky' references made permanent there.
_________________ CAUTION: Im no expert
| Top |
tubeAMP
Post subject: Re: Do I need to be afraid to touch my Zenith 7L05 chassis? Posted: Jan Thu 19, 2012 2:18 pm |
| Top |
wrnewton
Post subject: Re: Do I need to be afraid to touch my Zenith 7L05 chassis? Posted: Jan Thu 19, 2012 3:02 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5529 Location: Cleona, PA
| Top |
Frank in Selkirk
Post subject: Re: Do I need to be afraid to touch my Zenith 7L05 chassis? Posted: Jan Thu 19, 2012 6:24 pm |
Joined: Jan Mon 24, 2011 6:03 pm Posts: 88 Location: Selkirk,MB,Canada
To all the good advice I'd like to add,you will enjoy the hobby much more if you actually know what you're doing.Anybody can replace caps and such but if you don't know what each part does,it takes something away from really enjoying what you're doing.
| Top |
OZ132HOME
Post subject: Re: Do I need to be afraid to touch my Zenith 7L05 chassis? Posted: Jan Fri 20, 2012 4:00 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 4817 Location: La Porte, IN, USA
In my high school electronics class, we had isolation xformers available, but were also taught to check the plug polarity of each "hot chasis" radio we worked on. "Hot chassis" means the metal chassis is connected to one side of the AC power line when plugged in. One merely assures that the neutral (grounded) side of the line is connceted to the chassis, not the hot side. You do that with an AC voltmeter, which will read the voltage from the chassis to the receptacle ground terminal. You still need to exercise caution, since some of these sets have the line switch going to the chassis, which can make the chassis hot when the switch is off. Be careful!!!
_________________ Apolitical and Agnostic Forever (Well, on the Forum, anyway)! -OZ
| Top |
OZ132HOME
Post subject: Re: Do I need to be afraid to touch my Zenith 7L05 chassis? Posted: Apr Wed 25, 2012 4:40 pm |
Sorry for the delay in replying. I've been off. I can't find the schematic for your Zenith. Because of the possibility that the chassis connects to one side of the line through the on/off switch, which means it will be hot either when off or when on, depending on the plug polarity, I would assume the chassis to be "HOT" and make sure no one can contact it while plugged in. Either that or use an isolation transformer while working on it. When the chassis is in the (bakelite or wood) cabinet, with insulated knobs on and the back in place, it is assumed no one can touch the metal chassis.
| Top |
Eickerman
Post subject: Re: Do I need to be afraid to touch my Zenith 7L05 chassis? Posted: Apr Wed 25, 2012 4:53 pm |
| Member |
tubeAMP wrote: two handed is a no-no. your hands make a circuit across your chest. someone put the heart in there that doesnt like house current  I second that. Been there, done that, and made the hospital trip to prove it. Worst yet, I was doing something "safer" than working on a radio when it happened (disconnecting two "grounded" coax cables from each other).  Having said that, it is possible to safely work on these radios with proper precautions. I highly agree that a little time spent reading up on the subject will be time well spent in the long run. Curtis Eickerman
_________________ http://curtiseickerman.weebly.com
| Top |
OZ132HOME
Post subject: Re: Do I need to be afraid to touch my Zenith 7L05 chassis? Posted: Apr Wed 25, 2012 5:13 pm |
Finally found the schematic for your Zenith and got it to open with djvu. It does indeed have the on/off switch in the leg of the line that goes to the chassis. That means that with the switch on, one side of the line is connected to the chassis, but with the switch off, the OTHER side of the line is connected to the chassis, thru the tube filaments. Without modifying the circuit, this chassis may be hot in EITHER on or off mode, regardless of how the plug is inserted into an outlet. ! So, don't come in contact with the chassis while it's plugged in. And don't leave it plugged in while the chassis is out of the cabinet. Consider this a HOT CHASSIS set.
| Top |
wrnewton
Post subject: Re: Do I need to be afraid to touch my Zenith 7L05 chassis? Posted: Apr Wed 25, 2012 11:57 pm |
I've said it before: don't be AFRAID of these radios, but RESPECT them. Fear comes from not knowing how electricity works. Electricity is not unpredictable. If you take the reasonable precautions discussed in this post, you can troubleshoot live AC/DC sets.
_________________ Reece
| Top |
Users browsing this forum: Bugman, Faux and 10 guests |
