I have changed the paper caps and the three stage lytic on this Arvin 544A [http://www.nostalgiaair.org/PagesByModel/548/M0012548.pdf]. I checked all resistors and replaced one that was out of tolerance. I've taken multiple voltage readings and each time readings are satisfactory.
I have changed out the tubes 3 times still NO AUDIO. I do have sound from the speaker so I am confident that is not the problem.
Any suggestions as to what might be wrong would be appreciated.
http://www.nostalgiaair.org/PagesByModel/548/M0012548.pdf. I checked all resistors and replaced one that was out of tolerance. I've taken multiple voltage readings and each time readings are satisfactory.
