| Author |
magicclocks
Post subject: Re: persistant hum on philco after recap narrowed it down Posted: Apr Mon 30, 2012 8:24 am |
BikenSwim wrote: magicclocks wrote: Yes I have replaced the tube. I'll try grounding the pins with a cap. You said 1 uf should u touch the negative side to the chassis and I removed the 6s tube and I loose the hum too I didn't find any corrosion I loose reception too I'm working in that area and replacing anything I think could leak there are several mica caps in that area too I have on order in case one is leaking OK, pulling the 6SQ7 stops the hum, so the problem is there, not in the 7AF7. I bet if you ground the input grid, pin 2 of the 6SQ7 you will still have hum. It is a nice clean 60 Hz hum, not a power supply buzz, so I still think it is from pin 3 and pin 8 sharing a connection to the chassis. 60 Hz heater current is going from 6SQ7 pin 8 to ground, and if there is any resistance in that connection, it will feed a slight voltage into pin 3, the cathode, and the 6SQ7 will amplify it. If they are sharing a ground connection, cut the wire going to pin 8 and run a wire from Pin 8 to a different ground point, possibly pin 7 of one of the 6V6 tubes if that is near by. Or attach another ground lug to the chassis with a pop rivet or bolt, and run the pin 8 wire to it. In addition, see if you can improve the ground connection for pin 3, with solder to the chassis (difficult) or a bolt and star washer etc. Ok don I'll check that in the morning thanks sounds promising Don
_________________ DIGITAL CIRCUITS ARE MADE WITH ANALOG PARTS
| Top |
BikenSwim
Post subject: Re: persistant hum on philco after recap narrowed it down Posted: Apr Mon 30, 2012 4:06 pm |
Joined: Oct Wed 14, 2009 6:36 am Posts: 3023 Location: New York USA
I also realized that I am overhauling a GE console, and it had a hum after re-capping. Trying the line cord both ways in the outlet made no difference. I added a three-wire power cord, to ground the chassis, and that eliminated all the hum. I have added grounding cords to my public-address amplifiers to get rid of hum and "tingles" when you touch the chassis, as well. My set did not have any line-to-chassis capacitors. Don
| Top |
magicclocks
Post subject: Re: persistant hum on philco after recap narrowed it down Posted: Apr Mon 30, 2012 4:53 pm |
Can I add a grounded cord to this set I always hear that you can't ground these radio chassis
| Top |
BikenSwim
Post subject: Re: persistant hum on philco after recap narrowed it down Posted: Apr Mon 30, 2012 5:25 pm |
Your set has two .01 MFD capacitors on the input, one from each line to chassis. This puts 60 volts AC on the chassis, a good source of hum and tingles. I highly recommend a grounded power cord, and then you could remove those two capacitors, which may be in a tar block. Don
| Top |
K7PP
Post subject: Re: persistant hum on philco after recap narrowed it down Posted: Apr Mon 30, 2012 5:39 pm |
Joined: Jan Fri 13, 2012 6:52 pm Posts: 174 Location: Grays Harbor, Washington
Yes, you can add a three wire cord. It's a transformer powered set. Do yourself a favor and also add a 2 1/2 amp agc fuse and holder. Black power cord lead to the end of the fuse holder and the ring to the on off switch or transformer. White goes to transformer and green to chassis ground.
Hope this isn't a dumb question but I can't help wondering about the speaker. I know you said it was stock but it doesn't look stock. If memory serves, I think this model may have used an electrodynamic type speaker with a field magnet instead of a permanent magnet and if it does and if it's a replacement speaker, it may not have a bucking coil. Look to see if there are two extra contacts on the speaker that appear to be in series with the voice coil. It should be wound around the electromagnet and allow any voice coil movement caused by hum to create a 180 degree out of phase signal that cancels any voice coil movement created by the field coil, hence, cancels any hum.
I just went an looked up the drawing for the set on Ryders and it shows that it is suppose to have one. Also, what I hear on your recording sounds like 120 cycle hum but it's hard to tell.
If it is 120 cycle hum it's power supply created. It's hard to tell from the recording.
If it's 60 cycles, then the guys are right about it being a possible filament 60 cycle ground loop.
Anyway, I may be barking up the wrong tree on the speaker but it's a tree that's really easy to eliminate buy a quick look.
Best, Pete
| Top |
magicclocks
Post subject: Re: persistant hum on philco after recap narrowed it down Posted: Apr Mon 30, 2012 6:37 pm |
it for sure a field coil speaker it had the ohms written on the coil too that matches the schematic must have been the way it looked on video, and ps i have been trying all the options none seem to be helping so far One of my test voltages are low the first power test from ground point C to point B is 160 volts it should be 200v I have replaced all the things it says cause that except the output xformer
| Top |
Eickerman
Post subject: Re: persistant hum on philco after recap narrowed it down Posted: Apr Mon 30, 2012 7:05 pm |
| Member |
magicclocks wrote: One of my test voltages are low the first power test from ground point C to point B is 160 volts it should be 200v I have replaced all the things it says cause that except the output xformer Maybe I am mis-reading something. It doesn't look like point B connects to the output transformer at all. I only see it going to the 1st Audio Amplifier and the Phase Inverter. Curtis Eickerman
_________________ http://curtiseickerman.weebly.com
| Top |
magicclocks
Post subject: Re: persistant hum on philco after recap narrowed it down Posted: Apr Mon 30, 2012 7:44 pm |
In the literature in the first pages for testing voltages from the rectifier it shows the test points . And at test point B it should be 200 v. And the remedies or causes it lists the last one is t200 .i haven't really thought about why. Just sayin that's something but I have replaced all the other causes it lists
| Top |
ictjayhawk
Post subject: Re: persistant hum on philco after recap narrowed it down Posted: May Tue 01, 2012 1:01 am |
Joined: Mar Sat 06, 2010 11:34 pm Posts: 185 Location: Las Vegas, NV
Yes but it lists T200 as a cause of high voltage, not low voltage at test point B.
I assumed you checked and have about -65 VDC at the negative end of C103 (and I do mean at the cap itself.).
| Top |
magicclocks
Post subject: Re: persistant hum on philco after recap narrowed it down Posted: May Tue 01, 2012 2:45 am |
just checked. Yes I have -64.5 volts there.
| Top |
magicclocks
Post subject: Re: persistant hum on philco after recap narrowed it down Posted: May Tue 01, 2012 11:28 pm |
well hope nodody will kill me but I got rid of the hum completely . capacitor c 104 a .5uf cap that comes from the rectifier . I was determined to find the problem so I got the schematic blown up and a real nice one someone here gave me . I started to check voltages everywhere it showed it. I didnt get very far the first place I went to look I noticed that one end of c 104 wasnt to a ground. So I looked at the schematic for a half hour to make sure I screwed it up I had soldered the connection one tab over to the left on the drawing by accident . I changed it and eureka its perfect now . Thank you everybody for all your help, without the help I wouldn't have been so determined to fix it . Now I can try to get FM working . AM and SW work great I'll keep you all informed
| Top |
BikenSwim
Post subject: Re: persistant hum on philco after recap edit I got it Posted: May Wed 02, 2012 3:08 pm |
That makes sense. I noticed earlier that .5 MFD capacitor filters the bias for the 6SQ7, which is unusual since that tube usually uses a grid leak or cathode bias. I didn't mention to check it as you said you changed all the capacitors, while that should have been the clue! Don
| Top |
Eickerman
Post subject: Re: persistant hum on philco after recap narrowed it down Posted: May Wed 02, 2012 3:48 pm |
| Member |
magicclocks wrote: well hope nodody will kill me but I got rid of the hum completely . You wouldn't be the first person to solder something to the wrong terminal. If I only had a dollar for every time I...  Curtis Eickerman
| Top |
magicclocks
Post subject: Re: persistant hum on philco after recap edit I got it Posted: May Wed 02, 2012 6:23 pm |
| Top |
tubeAMP
Post subject: Re: persistant hum on philco after recap edit I got it Posted: May Wed 02, 2012 8:25 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 2755 Location: Gainesville, Florida
ah you didnt ground the ennnnnhhh out of it
_________________ CAUTION: Im no expert
| Top |
NumberMaj 1
Post subject: Re: persistant hum on philco after recap edit I got it Posted: May Thu 03, 2012 3:35 am |
Don, you called it, it was missing from the circuit. Bill J.
| Top |
radiopicker
Post subject: Re: persistant hum on philco after recap edit I got it Posted: May Thu 03, 2012 4:26 am |
| Member |
Joined: Aug Thu 18, 2011 4:48 am Posts: 2497 Location: Stamford, NY
Nice work!
_________________ Vincent
| Top |
Eickerman
Post subject: Re: persistant hum on philco after recap edit I got it Posted: May Thu 03, 2012 1:13 pm |
| Member |
| Top |
