It is currently May Thu 23, 2013 7:26 am
 Post subject: Zenith 6G601M - missing chassis screws
PostPosted: Apr Fri 27, 2012 6:12 pm
I just got this portable over the weekend - you can see it here: http://www.antiqueradios.com/forums/viewtopic.php?p=1603675#p1603675
It looks like it's complete except for two things - the chassis screws. Since the screw heads would be clearly visible on the sides, I want to make sure I'm using the right type of screw. Can anyone show me what the original screws look like?
Jeff N3NKN
"I have no interest in ordinary humans." - The Melancholy of Haruhi Suzumiya
 Post subject: Re: Zenith 6G601M - missing chassis screws
PostPosted: Apr Sat 28, 2012 1:54 am
Mine has sheet metal screws. They are a flat-top, Phillips head, countersunk type. I think "oval" head might be the closest you'll find today at the "usual" suspects (Lowe's, etc.). They won't stick out as far as a pan head will. My radio is the aluminum cased version, but I think they would have used the same type screws so the heads would be flush with the sides.
PostPosted: Apr Sat 28, 2012 5:06 am
As Kent said. Oval head, but maybe not quite so rounded as modern ones. They are definitely domed, though, and not perfectly flat on top like a flathead. Mine is the alligator finished leatherette version. No reason your straw version should be different from our two variants.
Oh, and they seat into a dished washer. I did not notice in your photo if yours were still stuck on or missing.
Edit: I don't have a good picture, but maybe you can judge by this one what it should look like. They are not countersunk enough to be flush with the surface.
Ron Mc/
PostPosted: Apr Sat 28, 2012 2:59 pm
OK, i recognize that type of screw. I can get those at a local hardware store, along with the dished washers.
I did some more Googling and found this pic at Radiomuseum:
http://www.radiomuseum.org/forumdata/upload/6-G-601-D_Sailboat_%239_si_kitty46cat_COPneu.jpg
It's hard to tell in either pic if these are black or tarnished brass, but I'm leaning toward brass. I think I can get those screws in an "antique brass" finish, which would come pretty close.
Jeff N3NKN
PostPosted: Apr Sun 29, 2012 1:51 am
I think mine were brass plated. They are very dark now, but they are definitely steel.
Ron Mc/
PostPosted: May Tue 01, 2012 12:10 am
Hope this helps. Steel, dark colored.
Ed
PostPosted: May Tue 01, 2012 6:53 pm
Mine are dark, almost black. That could be from age. I don't think that they're bronze. If the new ones are too bright, take a black Sharpie marker to them. Tht will work for a while, although it will wear off.
PostPosted: May Tue 01, 2012 9:20 pm
Here's another one..
kb3wbb
My radio files free download page:
http://www.enter.net/~rocketeer/radio/radio2.html
PostPosted: Dec Sun 09, 2012 4:03 am
J.Paul,
I have a couple the screws you need email me and I will mail them to you.
Ronnie
rlee12@bak.rr.com
Post New Topic Post Reply  [ 9 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: Google Adsense [Bot] and 5 guests
