Page 1 of 1
[ 10 posts ] |
| Author |
cpgixxer
Post subject: Grundig so-123 tuning eye sub to 6e5 not working Posted: Apr Sun 29, 2012 3:00 am |
I followed this article to a tee, subbing em34 http://www.nostalgiaair.org/forums/Mess ... 028055.htmThe green wire, which is one of the wires that control the tuning eye degree doesn't go above 1 volt, im supposed to see 5-16v. I checked the ef89 tube which is what I believe feeds the green wire, I even subbed another tube. I'm receiving am and fm perfectly. I checked resistors coming off that pin, all in spec. There's a weird silver barrel, small, says 10/100 120volts, not sure if this is a cap. I'm lost at this point....is it cap that steps up voltage? The diagram I'm using shows an em84 tube, the model could have one or the other eyes. http://radiolamp.nl/images/schema's grundig/so126/so126 schema.jpg Thanks
| Top |
Trent
Post subject: Re: Grundig so-123 tuning eye sub to 6e5 not working Posted: Apr Sun 29, 2012 4:15 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 622 Location: Kenosha, WI, US
The directions you linked to seem correct. I assume by "not working" you mean that the shadow is not changing. If it's not illuminating, that's a whole other discussion.
Some things that might get you on the right track: -the voltage that controls the shadow is negative. Do you mean -5 to -16? -this voltage comes from AVC circuit, which originates at the EABC80. If no negative voltage, look in circuitry in that area for problem, not EF89. -Are you sure the wire that previously was at pin 4 of the EM34 is now on pin 3 of the 6E5? -and, importantly... Are you using a traditional 6-pin U.S.-style 6E5 or are you using a russian-made 6E5C (or maybe called 6E5s) that has eight pins? If so, pin outs are totally different and the instructions you linked to are inapplicable.
_________________ Trent Nicol
| Top |
FM Refugee
Post subject: Re: Grundig so-123 tuning eye sub to 6e5 not working Posted: Apr Sun 29, 2012 3:55 pm |
| Member |
Joined: Sep Fri 07, 2007 2:21 am Posts: 1821 Location: Brunswick, ME 04011 (USA)
...the 'silver barrel' is probably an electrolytic cap (does it have + or - markings on the ends?); the value suggests it's the electrolytic that you typically find in the FM detector stage (again, the EABC80 tube area)... ...btw, your link to the schematic was incomplete... http://radiolamp.nl/images/schema%27s%20grundig/so126/so126%20schema.jpg... ...are you sure you've got the right model? That schematic covers four models, SO 123/124/126/170, 1959-60 time frame, all miniature tubes, stereo (for tape/phono only) capability--and console-style. Too new for an EM34 eye tube (it calls for an EM 84, which is the blue-green 'bar' type rather than the round green 'eye'--and considerably easier to get than an EM34, from what I understand)...also, no 10µF 100/120V cap (referring back to your 'silver barrel') to be found anywhere on there...calls for a 4µF 70/80V in the FM detector (C41)...
| Top |
cpgixxer
Post subject: Re: Grundig so-123 tuning eye sub to 6e5 not working Posted: Apr Sun 29, 2012 6:05 pm |
Wrong back plate, its got a 132 backplate, the set is a so172. I have it figured out, ebf89 and ef89 were reversed. I had replaced a number of caps and resistors that were out of spec or shorted, did the can too. Sounds beautiful and tuning eye works great. Here's a pic of the set and tube layout for reference.   New owner had no clue what tubes went where, nor did he have a manual or schematic. He has had the set in his basement for years and has never heard it play, I think he'll be happy.
| Top |
cpgixxer
Post subject: Re: Grundig so-123 tuning eye sub to 6e5 not working Posted: Apr Sun 29, 2012 6:08 pm |
| Top |
Trent
Post subject: Re: Grundig so-123 tuning eye sub to 6e5 not working Posted: Apr Mon 30, 2012 1:51 am |
Terrific!
| Top |
FM Refugee
Post subject: Re: Grundig so-123 tuning eye sub to 6e5 not working Posted: Apr Mon 30, 2012 2:37 am |
| Member |
...found the SO172 at Radiomuseum.org and looked at that schematic...that's more like it...
| Top |
cpgixxer
Post subject: Re: Grundig so-123 tuning eye sub to 6e5 not working Posted: Apr Mon 30, 2012 3:57 am |
You must a member, my magnifying glass doesn't work so well with their postage stamp diagrams  My handwritten one is wrong, the 2 farthest left tubes should be ecc83's.
| Top |
FM Refugee
Post subject: Re: Grundig so-123 tuning eye sub to 6e5 not working Posted: Apr Mon 30, 2012 4:13 pm |
| Member |
...yes, I am a member  ...
| Top |
radiotechnician
Post subject: Re: Grundig so-123 tuning eye sub to 6e5 not working Posted: May Tue 01, 2012 2:36 am |
Joined: Sep Thu 23, 2010 6:37 am Posts: 3942 Location: Powell River BC
Tell us about the CRT between the scope and the cap tester on the back of your bench.
_________________ de VE7ASO VE7ZSO Amateur Radio Literacy Club. May we help you read better. Steve Dow ve7aso@rac.ca
| Top |
