Page 1 of 1
[ 15 posts ] |
| Author |
CarlosRadio
Post subject: AK10 4700 restoration Posted: Apr Fri 20, 2012 2:34 pm |
Joined: Jan Tue 25, 2011 4:28 pm Posts: 231 Location: Elche (Alicante) 03203 Spain
Hello, friends. Finally I have my first Atwater Kent Breadboard 10. I'm very happy to have this radio and appears to be in very good original condition. I've been checking the audiotransformers and these are good. I did as directed by this forum post. viewtopic.php?f=6&t=116638My question is, is 2 meg ohm grid leak resistor within the same island of xfomers? And, if so, how can I check the grid leak resistor without opening the pot? Here you can see some pictures of my radio. Thank you and grettings form Spain Carlos
_________________ http://carlostuberadios.nixiweb.com/ https://picasaweb.google.com/104539521940170409700
| Top |
A A Kent
Post subject: Re: My first AK10 4700 Posted: Apr Fri 20, 2012 2:46 pm |
Joined: Feb Wed 25, 2009 4:06 pm Posts: 793 Location: Morristown, N.J.
The 2 meg resistor is in the "island" on the right- the three tube detector/amplifier. Just remove the four screws around the edge of the det/amp and the top will lift up slowly from the front. The resistor is soldered inside the top in a little glass sleeve; simply unsolder it and pull out the open element and replace it with a common resistor. There is a little piece of paper in the sleeve and it should stay there.
Usually both transformers are bad; the gentleman who makes the ARBEIII power supplies also sells replacement transformers that work very well. The original transformers are covered with lots of brittle tar which you will have to chip away. Generally I save the tar and remelt it, pouring it over the replacements; that has to be done in a disposable can heated slowly outdoors with a propane torch. You may just choose the chuck the tar.
Pete
| Top |
CarlosRadio
Post subject: Re: My first AK10 4700 Posted: Apr Sat 21, 2012 3:25 pm |
| Top |
CarlosRadio
Post subject: Re: My first AK10 4700 Posted: Apr Sat 21, 2012 6:29 pm |
| Top |
dneprrider
Post subject: Re: My first AK10 4700 Posted: Apr Sun 22, 2012 2:55 am |
Joined: Dec Sat 08, 2007 11:13 pm Posts: 369 Location: Nova Scotia
CarlosRadio wrote: I need to locate this resistor. But I do not see anywhere. In my 10b that resistor is under a potentiometer island. See in the picture the flat resistor shown in the bottom. Yours may be under a component island in your set perhaps?
| Top |
CarlosRadio
Post subject: Re: My first AK10 4700 Posted: Apr Sun 22, 2012 10:39 am |
dneprrider wrote: CarlosRadio wrote: I need to locate this resistor. But I do not see anywhere. In my 10b that resistor is under a potentiometer island. See in the picture the flat resistor shown in the bottom. Yours may be under a component island in your set perhaps?  Thank you, friend. You have given me a clue. Finally l resistor was on the inside of one of the coils. Was open. I have changed and the radio works. I was lucky because the audio transformers were good. Thank you.
| Top |
CarlosRadio
Post subject: Re: My first AK10 4700 Posted: Apr Tue 24, 2012 5:06 pm |
| Top |
CarlosRadio
Post subject: Re: My first AK10 4700 Posted: Apr Tue 24, 2012 9:16 pm |
| Top |
CarlosRadio
Post subject: Re: My first AK10 4700 Posted: Apr Tue 24, 2012 9:26 pm |
| Top |
CarlosRadio
Post subject: Re: AK10 4700 restoration Posted: Apr Tue 24, 2012 9:45 pm |
| Top |
dneprrider
Post subject: Re: AK10 4700 restoration Posted: Apr Tue 24, 2012 10:56 pm |
CarlosRadio wrote: All right. I made the first test. Here's the video. It works. Although I have to find a good antenna. Any suggestions? http://www.youtube.com/watch?v=WL5TaWs4ubII am very glad you have it working. It sounds very good. For my antenna I have been using a long wire strung outside my house as I have a very large back garden. I tried a small internal wire antenna on the floor connected to a home built transistor RF amplifier. It did work but not as well as the outside long antenna.
| Top |
CarlosRadio
Post subject: Re: AK10 4700 restoration Posted: Apr Wed 25, 2012 8:22 am |
| Top |
Tube Radio
Post subject: Re: AK10 4700 restoration Posted: Apr Thu 26, 2012 2:20 pm |
| Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 7854 Location: Warner Robins, GA
Your radio sounds very nice.
| Top |
CarlosRadio
Post subject: Re: AK10 4700 restoration Posted: Apr Sun 29, 2012 11:54 am |
| Top |
CarlosRadio
Post subject: Re: AK10 4700 restoration Posted: Apr Mon 30, 2012 5:29 pm |
| Top |
Who is online |
Users browsing this forum: fifties, Google Adsense [Bot], Google [Bot], Prutser and 8 guests |
