It is currently May Sun 26, 2013 3:06 am
 Post subject: Philco (51B), alignment , condenser box and rust
PostPosted: May Thu 03, 2012 10:43 pm
I obtained a Philco 51B on E-Bay. It was in pretty bad shape. It looked like it had been in water for years, completly rusted. After cleaning it up and replacing the e-caps the old radio came to life! I have rebuilt the backlight caps and the sound improved. Now for the problems.
The box with 5 caps contains .1, .15, .25 and 2-.5mf caps. I cannot find the individual size of the caps? When disconnected each measures 1.4 mf ? How can I find the individual size?
I got most of the rust off but for the gang condenser. Is there an easy way to remove the rust from the gang condenser?
I cannot find an alignment procedure for this radio. It is hit or miss! Is there an alignment procedure?
Richard
rgkadams@gmail.com
Sunny Southwest Utah
 Post subject: Re: Philco (51B), alignment , condenser box and rust
PostPosted: May Thu 03, 2012 10:55 pm
I can't find anything specific to a 51B but found this;
http://www.philcoradio.com/tech/images/50.jpg
It's from a 50 but may be the same?
Phil
I've been doing so much for so long with so little I can now do anything with nothing!
PostPosted: May Fri 04, 2012 2:24 am
Nostalgia air has the schematic for a 51, the 51 and 52 are supposed to have the same chassis as the 51B baby grand.
Corby
PostPosted: May Fri 04, 2012 2:56 am
I have the schematic, but no alignment precerure and no cap sizes just #23 for the cap box on the schematic?
Richard
rgkadams@gmail.com
PostPosted: May Fri 04, 2012 3:09 am
Some info here:
http://antiqueradios.com/forums/viewtopic.php?t=56119
PostPosted: May Fri 04, 2012 4:19 am
That looks good. Thank you! :D
Now the rust and alignment? :lol:
Richard
rgkadams@gmail.com
PostPosted: May Fri 04, 2012 4:23 am
The schematic I linked to has the same condenser block and values,have you compared the connections to your 51B?
Phil
PostPosted: May Fri 04, 2012 4:59 pm
Yes it is the same and I have identified all the cap. :D Now should I replace them? The radio sound vary good for a 5" speaker! It is a very touchy radio. Every tine I change some thing out it stops working and I have to monkey with the alignment to get it going. That is why I need a percedre.
Richard
rgkadams@gmail.com
Post New Topic Post Reply  [ 8 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: bainer1290, Bill njb, Johnny, morganboy, Philco Fan and 7 guests
