Page 1 of 1
[ 8 posts ] |
| Author |
rgadams
Post subject: Philco (51B), alignment , condenser box and rust Posted: May Thu 03, 2012 10:43 pm |
Joined: Jun Sun 08, 2008 11:18 pm Posts: 247 Location: Toquerville Utah
I obtained a Philco 51B on E-Bay. It was in pretty bad shape. It looked like it had been in water for years, completly rusted. After cleaning it up and replacing the e-caps the old radio came to life! I have rebuilt the backlight caps and the sound improved. Now for the problems.
The box with 5 caps contains .1, .15, .25 and 2-.5mf caps. I cannot find the individual size of the caps? When disconnected each measures 1.4 mf ? How can I find the individual size?
I got most of the rust off but for the gang condenser. Is there an easy way to remove the rust from the gang condenser?
I cannot find an alignment procedure for this radio. It is hit or miss! Is there an alignment procedure?
_________________ Richard
rgkadams@gmail.com
Sunny Southwest Utah
| Top |
Philco Fan
Post subject: Re: Philco (51B), alignment , condenser box and rust Posted: May Thu 03, 2012 10:55 pm |
Joined: Jul Tue 18, 2006 5:23 am Posts: 5172 Location: Roseville,Ca
I can't find anything specific to a 51B but found this; http://www.philcoradio.com/tech/images/50.jpgIt's from a 50 but may be the same? Phil
_________________ I've been doing so much for so long with so little I can now do anything with nothing!
| Top |
corbymite
Post subject: Re: Philco (51B), alignment , condenser box and rust Posted: May Fri 04, 2012 2:24 am |
Joined: Jan Thu 19, 2012 9:35 pm Posts: 307 Location: Lompoc, CA 93436
Nostalgia air has the schematic for a 51, the 51 and 52 are supposed to have the same chassis as the 51B baby grand.
Corby
| Top |
rgadams
Post subject: Re: Philco (51B), alignment , condenser box and rust Posted: May Fri 04, 2012 2:56 am |
I have the schematic, but no alignment precerure and no cap sizes just #23 for the cap box on the schematic?
rgkadams@gmail.com
| Top |
mbear2k
Post subject: Re: Philco (51B), alignment , condenser box and rust Posted: May Fri 04, 2012 3:09 am |
| Member |
Joined: Nov Fri 06, 2009 1:04 am Posts: 1292 Location: Rochester, NY 14425
| Top |
rgadams
Post subject: Re: Philco (51B), alignment , condenser box and rust Posted: May Fri 04, 2012 4:19 am |
That looks good. Thank you! Now the rust and alignment?
rgkadams@gmail.com
| Top |
Philco Fan
Post subject: Re: Philco (51B), alignment , condenser box and rust Posted: May Fri 04, 2012 4:23 am |
The schematic I linked to has the same condenser block and values,have you compared the connections to your 51B? Phil
| Top |
rgadams
Post subject: Re: Philco (51B), alignment , condenser box and rust Posted: May Fri 04, 2012 4:59 pm |
Yes it is the same and I have identified all the cap.  Now should I replace them? The radio sound vary good for a 5" speaker! It is a very touchy radio. Every tine I change some thing out it stops working and I have to monkey with the alignment to get it going. That is why I need a percedre.
rgkadams@gmail.com
| Top |
