Page 1 of 1
[ 3 posts ] |
| Author |
Rich K.
Post subject: alignment question Posted: May Sat 05, 2012 10:42 pm |
| Member |
Joined: Aug Tue 30, 2011 11:25 pm Posts: 934 Location: Charlevoix, Michigan, USA
According to the alignment instructions for my Silvertone Model 1970A, after I get the IF aligned I am supposed to connect my signal generator to the antenna lead through a .00025uF (250pf) capacitor. All I have in my junk box is a .0005uF and a .0001uF. Will it make all that much of a difference if I use one of those? If not, which one would be better for me to use? Also, they want me to use a 400-ohm resistor instead of the capacitor for aligning the police and shortwave bands; all I have is 330-ohm. Again, will it make all that much of a difference?
| Top |
wrnewton
Post subject: Re: alignment question Posted: May Sun 06, 2012 12:06 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 5529 Location: Cleona, PA
I usually just lay the output cable of the S/G near the radio and pick up enough signal that way. You want to reduce the output of the S/G so you just barely hear the signal so that the AVC doesn't kick in, and it's easier to hear the peak that way.
_________________ Reece
| Top |
Jack Shirley
Post subject: Re: alignment question Posted: May Sun 06, 2012 12:36 am |
| Member |
Joined: Mar Fri 14, 2008 1:40 pm Posts: 8405 Location: SE USA
Me too, Reece. Unless the radio has been severely messed with. The 'official' alignment procedures assume the worst case scenarios and sometimes are overkill for just tweaking out a working radio.
_________________ The beatings will continue until the morale improves
| Top |
Users browsing this forum: No registered users and 5 guests |
