It is currently May Wed 22, 2013 10:01 am
 Post subject: Astatic Cartridge for Philco 46-1201
PostPosted: May Fri 04, 2012 12:57 pm
Anyone have any idea where I might get one of these or a substtute.
Thanks Tex[imImageg]
 Post subject: Re: Astatic Cartridge for Philco 46-1201
PostPosted: May Fri 04, 2012 1:00 pm
the phono forum :shock:
also I had found good selection and prices in eBay stores for stylus. should have the same for cartridges
CAUTION: Im no expert
PostPosted: May Fri 04, 2012 1:02 pm
I use http://www.west-techservices.com/ but there are others also - Google or the Resources list is your friend! West-Tech can rebuild the cartridge, or supply a suitable modern replacement.
Dave McClellan, W6SQV(/4)
http://mcclellans.com/RadiosPage9-2010.htm
PostPosted: May Fri 04, 2012 1:43 pm
Thanks for the leads, I'll see about having it rebuilt.
Tex
PostPosted: May Sat 05, 2012 3:33 am
If you want a modern replacement try Kens Electronics.com he has generic high output replacements.
E. :)
PostPosted: May Sat 05, 2012 3:16 pm
I just restored one of these philcos and used a sub "turnover" that had a 1.4 volt output. Got it from VM Audio Enthusiasts (Gary) . It was a Pfanssteil plug in that came with a turnover holder and it had a 78 3 mil saphire needle on each side so that you can flip it and have a new needle instantly. It worked just fine. The original cartridge you have is an Astatic 146 which is a rare bird nowadays. Note: There is a voltage divider that the original cartridge is connected to and I recommend you eliminate it since you sub cartridge will not have as much output at that old Astatic 146 which originally put out about 4 volts or so.
Post New Topic Post Reply  [ 6 posts ]  Moderators: Marcc, Norm Leal
