It is currently May Wed 22, 2013 10:08 am
 Post subject: KLH Radio # 21 Troubles Need Help Please
PostPosted: May Thu 10, 2012 12:42 am
I recently Picked up a KLH Radio it has no power & No Sounds what do i start to xhexk>?
Thanks Any help is appreciated
sincerely william S
PLease Visit me on my You Tube Channel
http://www.youtube.com/user/radioman56
Last edited by antiqueradiobuff on May Thu 10, 2012 11:32 am, edited 1 time in total.
 Post subject: Re: KLH Radio Troubles Need Help Please
PostPosted: May Thu 10, 2012 12:56 am
When the set is DOA, I start at the AC plug and work inward from there, through the power cord, the fuse if any, and the power switch. If I haven't turned up the problem by that time, the power supply is next.
My usual experience with DOA cases is an open power cord, usually at the base of a molded AC plug or at the point of chassis entry.
PostPosted: May Thu 10, 2012 1:05 am
Model number?
I've had two KLH Twenty Ones (FM only) that were DOA. In both cases the audio driver (not output) was the problem. One also had some circuit board traces cracked around the tone controls.
The beatings will continue until the morale improves
PostPosted: May Thu 10, 2012 6:20 am
Also, look around the power transformer, they were not well mounted, and a drop can break the wires loose.
PostPosted: May Thu 10, 2012 11:32 am
Jack Shirley wrote:
Model number? Yes Jack Model 21 sorry I for got
 Post subject: Re: KLH Radio # 21 Troubles Need Help Please
PostPosted: May Thu 10, 2012 12:26 pm
I hope you do fix the radio, its a great sounding unit. A freind of mine has hounded me for years to give it to him, no chance. He will get it when I go to the land beyond, its in my Will! If you have a schematic for the 21 could you send me a copy? I'd appreciate.
john85
PostPosted: May Thu 10, 2012 1:17 pm
john85
if i fix it it maybe forale depending if and when i get it fixed I have not yet decied yet it heeds a reglueing of the knob on the dial and new grille cloth nothing there now I do not know where to get this origtnal grille cloth.
maybe grillecloth.com
PostPosted: May Thu 10, 2012 6:46 pm
:D Good News Guys and Bad news first the good news the radio is ok sounds awesome . Now the bad news the speakers worn out no sound comming from it at all. I have some Nos Bose car speakers from the factory my friend use to work there any who. i hooked it up to this and it is working awesome But I am not sure if I should have the oldone fixed if the radio is not worth much ill see if I can get a suitable replacement with a big magnit
Thanks for all the help Much appreciated
:D
Post New Topic Post Reply  [ 8 posts ]  Moderators: Marcc, Norm Leal
