It is currently May Fri 24, 2013 6:20 pm
 Post subject: Philco 49-901 secretary chassis pic?
PostPosted: Jun Thu 14, 2012 4:10 am
Hi all ,looking for a pic of a chassis for the Philco secretary.The color wheel on mine was off and I'd like to see how it was attached originally.A clip of some sort?? Thanks for any help!
 Post subject: Re: Philco 49-901 secretary chassis pic?
PostPosted: Jun Thu 14, 2012 6:57 am
Hi RN,
I can get you somepics of that in the morning. I have more than one I need to restore.
As far as I remember, the color wheel slipped on a shaft similar to the volume control half shaft. That way, it will be the correct position each time.
Will get the photos ASAP.
EDIT, RUnning late, will get them in a few minutes.
Gary Rabbitt
PostPosted: Jun Fri 15, 2012 6:37 am
OK, sorry for the delay, been a hectic day.
The wheel is attached onto a slotted sleeve. On the shaft is a pin that goes through and sticks out of the sides of the shaft. (Mine needs to be pushed through just a little.
The pin goes between two of the slots so it does not slip.
Do you have your wheel or what? The wheel is curved, but could probably be made. Transparent paints are then used to color in the wedges.
You can see where I had to glue the wheel back onto the retainer sleeve.
Hope this helps you (or anyone) out.
Gary Rabbitt
PostPosted: Jun Fri 15, 2012 11:03 am
Gary, thanks for the pics! I have the wheel and sleeve,but the wheel is off the sleeve.I guess I'll glue it like you did.I thought there might be a clip holding it on......
PostPosted: Jun Fri 15, 2012 10:20 pm
Hi,
The disc originally just slipped over the metal sleeve and had a dot of glue on it.
I had to carefully glue it in the right place. You may be able to see where yours has broken off, and you can match it up.
That way, you can maintian the correct position of the colors.
Lube, and or clean the mechanical changer, contact clean the station selector switch.
Do you have your set recapped and working? They are a pretty cool set to have in your collection.
Take care,
Gary Rabbitt
PostPosted: Jun Sat 16, 2012 2:01 am
Gary, yes mine is re-capped and working,quite well I might add.Which color section on the wheel is lined up with the pin? Looks like the blue section? Thanks
Post New Topic Post Reply  [ 6 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: mjohansson2 and 6 guests
