It is currently May Thu 23, 2013 4:48 am
 Post subject: Weak Volume
PostPosted: Jun Fri 08, 2012 2:35 am
EMUD senior 60
Even after recapping paper caps the reception is weak. It is even weaker than before. I only get 2 local stations on Fm, one on Am.
Which stage is the trouble in OR how do I proceed?
M Khan
 Post subject: Re: Weak Volume
PostPosted: Jun Fri 08, 2012 5:38 pm
Schematic?
Any antenna connected?
Curtis Eickerman
PostPosted: Jun Sat 09, 2012 2:43 am
Hi:
I have the schematic, but the forum will not accept pdf.
Antenna is connected.
THanks and regards,
M Khan
PostPosted: Jun Sat 09, 2012 3:04 am
If you find a way to post it somewhere, I would take a look at it. Otherwise perhaps someone else here has more information available to them regarding this radio.
Best of luck.
Curtis Eickerman
PostPosted: Jun Sun 10, 2012 11:01 pm
Post the PDF in the Photo Gallery.
Upload just like you would a photo. You will not be able to see the visual in the gallery, only when you select to download the document.
Post the link to the file here in your thread.
Gary Rabbitt
Post New Topic Post Reply  [ 5 posts ]  Moderators: Marcc, Norm Leal
