Page 1 of 1
[ 9 posts ] |
| Author |
radio-tuber
Post subject: Grid Bias button cell replacements Posted: Jun Sat 30, 2012 11:35 pm |
Joined: Jan Thu 01, 1970 1:00 am Posts: 253 Location: Eureka, CA, USA
Mine is long dead and needs replacing. Anyone out there developed a workable go-around? I don't want to re-invent the wheel.......... I can clip in a AAA cell and holder, but would rather use something button-like.
Thanks in advance.
_________________ Jim Falls K6FWT Eureka, CA
| Top |
chaz
Post subject: Re: Grid Bias button cell replacements Posted: Jul Sun 01, 2012 12:06 am |
Joined: Nov Mon 05, 2007 11:08 pm Posts: 1073 Location: Calgary Alberta
Jim I have several Rogers radios and many of them hav bias cells .. What I have done is solder a 1.5 volt hearing aid battery in place and it seems to work for me.. I got the idea from others on the forum. Just make sure you get the polarity right,,the outside of the bias cell is negative..
_________________ When The Student Is Ready,,The Teacher Will Appear
| Top |
Norm Leal
Post subject: Re: Grid Bias button cell replacements Posted: Jul Sun 01, 2012 1:13 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 28955 Location: Livermore, CA
Jim
You could replace the bias cell but may not need it? Later radios did away with bias cells for some circuits. These circuits use a cap coupling to the tube with high value grid resistor. Best to have model number so a schematic can be viewed.
_________________ Norm
| Top |
radio-tuber
Post subject: Re: Grid Bias button cell replacements Posted: Jul Sun 01, 2012 1:44 am |
This is the Silvertone farm set I got running last night (Home team won 9 to 1!) http://www.nostalgiaair.org/PagesByMode ... 017342.pdfBeen experimenting - Seems to work OK with or w/o it. I jumped it w/ alligator clips - works OK. When I jump in a 1.2 VDC battery, the volume drops slightly but the background hash decreases (better signal/noise ratio?). Easier reception of SW signals. I cleaned up the battery and holder clip contacts and measured 0.8V on the cell (2/3 it's value when new in 1938). Slid it back into the holder. No major difference between that and the 1.2V battery jumped in. Maybe I'm trying to solve a problem that really isn't one..........? PS: I LIKE the hearing aid battery idea! Glad someone has done that successfully.
| Top |
Oldbear
Post subject: Re: Grid Bias button cell replacements Posted: Jul Sun 01, 2012 3:18 am |
Joined: Jan Thu 01, 1970 1:00 am Posts: 3785 Location: St. Louis, MO, USA
| Top |
Dave Wise
Post subject: Re: Grid Bias button cell replacements Posted: Jul Wed 04, 2012 12:22 am |
Joined: Feb Thu 08, 2007 12:36 am Posts: 1164 Location: Hillsboro, Oregon
I rewired the circuit to add cathode bias, eliminating the cell. Can be done in some cases but not all.
Dave Wise
| Top |
Rich, W3HWJ
Post subject: Re: Grid Bias button cell replacements Posted: Jul Wed 04, 2012 12:41 am |
Joined: May Tue 30, 2006 4:46 pm Posts: 4805 Location: Santa Rosa, CA
Most hearing aid batteries are zinc/air and not intended for long life. I use #13 in my H/A.
I would think a lithium coin cell is the best bet. You don't need 3.6V, but in my other systems (computer, ham transceiver, walkie-talkie), the memory batteries have lasted as long as 18 years.
| Top |
RepairTech
Post subject: Re: Grid Bias button cell replacements Posted: Jul Wed 04, 2012 1:13 am |
| Member |
Joined: Jan Sun 24, 2010 7:59 am Posts: 6171 Location: Pro Tech, Philadelphia Pa.
Vintage Dave wrote: I rewired the circuit to add cathode bias, eliminating the cell. Can be done in some cases but not all.
Dave Wise Correct.... cathode bias eliminates the need for a bias battery. Also, jump the cathode resistor with a 22uf cap to "steady" the bias voltage. I've been doing that trick for years now. Works for me!
_________________ "Accept the fact that some days you are the pigeon, and some days you are the statue."
| Top |
Peter Bertini
Post subject: Re: Grid Bias button cell replacements Posted: Jul Wed 04, 2012 1:16 am |
| Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 12208 Location: Somers, CT
Rich, W3HWJ wrote: Most hearing aid batteries are zinc/air and not intended for long life. I use #13 in my H/A.
Rich Exactly. Once the seal is removed, they will self deplete in weeks. Pete
_________________ A long journey always begins with the words, "I think I know a shortcut."
| Top |
Who is online |
Users browsing this forum: No registered users and 6 guests |
