It is currently May Fri 25, 2018 9:12 pm
 Post subject: Crosley noisy tuning capacitor
PostPosted: Mar Tue 26, 2013 6:38 pm
I am restoring a Crosley 02CP. After replacing caps and some tubes and wiring, the radio works like a charm except the tuning capacitor is very noisy. When tuning to stations I get a lot of sparking and some dead spots. I have cleaned it with WD 40 and wiped it as clean as possible with pipe cleaners and then sprayed it with contact cleaner. The noise is the same. What can I do next to reduce the noise?
Richard
rgkadams@gmail.com
Sunny Southwest Utah
 Post subject: Re: Crosley noisy tuning capacitor
PostPosted: Mar Tue 26, 2013 10:20 pm
One thing to check is the mounting rubber/gromets. Sparking when tunning, stop on station, no movement, works like a charm. This assumes plates aren't touching. No more WD-40. Use matchbook thickness chip board between plates, see if you still get residue.
Bill J.
PostPosted: Mar Wed 27, 2013 12:44 am
I did get rid of all the noise except on the very low end by useing a high pressure air gun. :D
Richard
rgkadams@gmail.com
PostPosted: Mar Thu 28, 2013 8:15 am
Did you specifically clean the capacitor wiping contacts? It might also be a good idea to clean out the old grease from the end bearings relubing with light oil or a very small amount of grease
where does the sparking you mentioned come from? There should
not be
sparking.
PostPosted: Mar Thu 28, 2013 4:31 pm
It is not sparking just sparking noise from the speaker. Now it's just from the low end where the tuner is all mashed together. I think the tuner had dust or small particals in it.
Richard
rgkadams@gmail.com
PostPosted: Mar Thu 28, 2013 7:02 pm
Any way to disassemble this and straighten them??
PostPosted: Mar Thu 28, 2013 9:05 pm
I think he meant "meshed" together
PostPosted: Mar Sat 30, 2013 3:53 am
with a high power magnifying glass check that the plates are not touching. I have had to straighten tuners with plates that were just barely touching and the noise went away.
Everyone you meet is fighting a battle you know nothing about.
PostPosted: Mar Sat 30, 2013 4:22 pm
I think it has whiskers growing. Seem more common on sets from around WW-II era. You could disconnect all leads and use high voltage to burn off. Note the shock hazard and take precautions.
Post New Topic Post Reply  [ 9 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: fifties, Mr. Detrola, spsquires, Tom Albrecht and 14 guests
