It is currently Feb Sun 18, 2018 11:18 am
Post New Topic Post Reply  [ 431 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 22  Next
 Post subject: Re: marconi model 160
PostPosted: Jan Mon 09, 2017 11:59 pm
I checked it with the speaker and no noise and I even checked the speaker with a 9v battery also I will send a pic of that white wire
PostPosted: Jan Tue 10, 2017 12:03 am
here is the pic of the white wire that goes no where
PostPosted: Jan Tue 10, 2017 12:20 am
Where in the schematic is the white wire connected?
Do you have a low level audio source you can access with a plug & cable such as a cellphone or stereo with line level out, etc.? Connect it to the radio, ground lead to chassis and signal lead through a .1 cap to grid cap of 6Q7. See if you can hear the audio through the radio.
Matt
PostPosted: Jan Tue 10, 2017 12:26 am
Also, use spaghetti tubing or heat shrink tubing for insulation. Electrical tape is not the way to go.
Matt
PostPosted: Jan Tue 10, 2017 12:30 am
when you say line level out do you mean external speaker and has for the schematic and white wire I will have to look at it tomorrow but I know the white wire that you see goes to the if trans
PostPosted: Jan Tue 10, 2017 12:39 am
I mean a low level audio signal like a headphone jack on a phone or stereo or computer. Not a high power audio output like a speaker connection.
Matt
PostPosted: Jan Tue 10, 2017 12:45 am
ok I will have to look around for something to use but the signal generator any idea what might be wrong because I already recapped it and used it and I will try to figure out where the white wire is on the schematic
PostPosted: Jan Tue 10, 2017 12:57 am
the white wire is on the connection point of L7 opposite the connection pins 4 and 5 of tube 6q7 and one end c-22 connects to it also
PostPosted: Jan Tue 10, 2017 12:58 am
Here is the signal path for the 400 Hz audio output. Clean and inspect rotary switch S3. Check continuity of T1 windings. Check R6.
Matt
PostPosted: Jan Tue 10, 2017 1:01 am
thanks I will check that in the morning and also I posted what I think is the connection point of the mystery white wire
PostPosted: Jan Tue 10, 2017 1:12 am
Ok. This point should also be connected to R4 (1 Meg) and one lug of R5 (volume control). Are those connections still there?
Matt
PostPosted: Jan Tue 10, 2017 11:46 am
yes this point has r-4 I meg and one wire to the volume control but it also has this mystery wire
PostPosted: Jan Tue 10, 2017 4:28 pm
Is this the signal,generator or radio your working on?
KM4YTW
PostPosted: Jan Tue 10, 2017 5:13 pm
Devildog, we're working on both.
Squires, since the schematic shows that point has only 4 things connected (IF wire, C22, R4, R5), and we verified all of them, then the white wire is not needed. Somebody may have soldered it on as a temporary connection at one point.
Let's focus on the sig gen for a minute. Things will be easier if we know it's working right. Do you have a set of headphones with a stereo plug connector like this?
Matt
PostPosted: Jan Tue 10, 2017 5:16 pm
no I do not have any head phones or are you just looking for the plug
PostPosted: Jan Tue 10, 2017 5:27 pm
I was going to have you use the headphones to listen for the sig gen audio. Next time you have a chance, pick up a cheap $10 pair of headphones. In the meantime, let's try again with the permanent magnet speaker. Hook up the sig gen to it with the Output Multiplier on 400~A.F. and the Output Control at maximum. Listen with your ear next to the speaker for a faint tone.
Matt
PostPosted: Jan Tue 10, 2017 6:07 pm
no sound at all from the generator and the white looks to be a factory solder
PostPosted: Jan Tue 10, 2017 6:33 pm
I cleaned up the output control button and now have a noise in the speaker from 100 to 10 on the output control
PostPosted: Jan Tue 10, 2017 6:45 pm
Ok, good. Now hook the sig gen to the radio. Black to chassis ground. Red through .1 cap to 6Q7 grid cap.
Matt
PostPosted: Jan Tue 10, 2017 6:58 pm
had the noise from the generator and lost it again
Post New Topic Post Reply  [ 431 posts ]  Moderators: Marcc, Norm Leal Go to page Previous  1 ... 10, 11, 12, 13, 14, 15, 16 ... 22  Next
Users browsing this forum: No registered users and 16 guests
