It is currently Jul Sun 22, 2018 3:27 pm
Post New Topic Post Reply  [ 62 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: zenith 7j232 volume problem
PostPosted: Dec Mon 19, 2016 10:14 pm
I have a zenith 7j232 that was not working when I got it but now I have it all recapped but has only a low to medium volume thanks a0e 1k0 newfoundland Canada
 Post subject: Re: zenith 7j232 volume problem
PostPosted: Dec Mon 19, 2016 11:12 pm
Could it be a biasing problem ? I would check voltages on the plates and control grids.
KM4YTW
PostPosted: Dec Mon 19, 2016 11:15 pm
the voltage on pins 3 on both 6l5 and 1j6 is 83 dc v and it should be 122 on 6l5 and 133 on 1j6
PostPosted: Dec Mon 19, 2016 11:22 pm
Sorry I don't have the schematic but does it have a selenium rectifier??
KM4YTW
PostPosted: Dec Tue 20, 2016 1:53 am
Is this the correct schematic?
download-2.pdf [204.95 KiB]
Downloaded 72 times
KM4YTW
PostPosted: Dec Tue 20, 2016 2:12 am
Yes that is the schematic
PostPosted: Dec Tue 20, 2016 2:29 am
It hurts to look at it. Too many coils and such for me . Haven't had any dealings with that type of radio. But I'm sure someone will be along to help.
KM4YTW
PostPosted: Dec Tue 20, 2016 2:29 pm
May have a resistor that went up,in value . If all the voltages from the transformer look right , I would check the resistors associated with those tubes .
KM4YTW
PostPosted: Dec Tue 20, 2016 4:48 pm
Check and replace all out of spec resistors in the chassis. And have you replaced the resistors and capacitors that are under the subchassis inside the power supply box? Is your 6ZY5G rectifier tube in good condition?
John k9uwa
PostPosted: Dec Wed 21, 2016 1:15 am
I have not done anything with the resistors yet because I find the resistors do not have the color rings on them like the newer ones so I do not know how to read them properly
PostPosted: Dec Wed 21, 2016 2:35 am
Are they B.E.D. resistors??
Dogbone shaped??
The Body is the 1st color[number],the End is the 2nd color[number] and the Dot on the Body is the 3rd color[number].
Phil
I've been doing so much for so long with so little I can now do anything with nothing!
PostPosted: Dec Wed 21, 2016 6:25 am
Note the 1J6 has two pilot lamps 2.9 volt 170 mA and two 21 ohm 1/2 watt resistors in the filament circuit, bottom right of the schematic. The pilots must be correct and the resistors probably need to be replaced, for the 1J6 to get the 2 volts filament voltage for good output volume. There was another of these sets a few months ago, same problem.
Diode Don, all problems rectified.
Someone with less knowledge than I had been in there before ....
PostPosted: Dec Wed 21, 2016 12:20 pm
i checked one of the pilot lights that has no bulb and I get 5.9 ac v on the tube socket so good or bad
PostPosted: Dec Wed 21, 2016 12:41 pm
the resistors are mostly dog bone shape and some new ones
PostPosted: Dec Wed 21, 2016 12:52 pm
Devildog likes dog bones resistors. Lol. I have never been able to read a dog bone resistor, is there a chart somewhere that explains how to read them?
KM4YTW
PostPosted: Dec Wed 21, 2016 12:58 pm
Dogbone shaped??
Phil
-Mark http://pixellany.com
PostPosted: Dec Wed 21, 2016 1:24 pm
So, there all 3 color value resistors? Are these wire wound ?
KM4YTW
PostPosted: Dec Wed 21, 2016 2:11 pm
Most (all ?) resistors have at least 3 colors in the coding for value.
I think dogbones are carbon film?.....( not wire wound )
PostPosted: Dec Wed 21, 2016 2:23 pm
So there could not be a 220K ohm dog bone? Red, red, black ,orange? That's 4 colors. R would it be 2.2 K ohm, how would,you state That?
KM4YTW
PostPosted: Dec Wed 21, 2016 2:58 pm
Back to the basics of the 3-color code---applies to resistors and some capacitors:
1st digit: band 1 or "body"
2nd digit: band 2 or "end"
multiplier: band 3 or "dot"
The multiplier is the number of zeros
Some examples
red red red = 22 + 2 zeros = 2,200
red red orange = 22,000
brown red green = 1,200,000 = 1.2Mohm
220K = 220,000 => red red yellow
footnote:
you can think of the multiplier as an exponent in scientific / engineering notation---eg 2,200 = 22E2. this is not however normal practice---i.e. 2200 would be 2.2E3
Post New Topic Post Reply  [ 62 posts ]  Moderators: Marcc, Norm Leal Go to page 1, 2, 3, 4  Next
Users browsing this forum: analog.tv, frankradio1, HalliFan, jatroberg, lorenz200w, Roadster61, Skip, Steve Chambers and 15 guests
