It is currently Jan Mon 22, 2018 6:50 pm
 Post subject: Sonora rdu209
PostPosted: Jan Thu 12, 2017 5:11 am
Could someone explain to me where this radio gets its plate voltages from? Ive read the schematic a thousand times, but it just doesnt click with me.meIm also not understanding the 35z5 rectifier. I know that it makes pulsating dc that gets filtered, but where does the dc leave this tube and go to the radio?
 Post subject: Re: Sonora rdu209
PostPosted: Jan Thu 12, 2017 5:21 am
AC goes into the 35Z5 rectifier on the plate (after going through the dial lamp and part of the 35Z5 filament). The DC starts at the cathode of the 35Z5, which is pin 8. From there it goes through a 33 ohm resistor to the first filter cap (40 uF). From that point, there is a B+ feed to the output transformer. Note that this is a tapped output transformer. The bottom part of the primary coil is a "hum canceling" winding, and the B+ feed to the rest of the radio goes out the bottom terminal of the output transformer through a 1200 ohm resistor to the second filter cap (also 40 uF). From this point, all the rest of the radio gets its B+.
Schematic available here: http://www.radiomuseum.org/r/sonora_rad_rdu209.html
Tom K6VL
PostPosted: Jan Thu 12, 2017 7:02 am
Good explanation above. The 35Z5 is a diode. Makes AC into 1/2 wave DC. Gets filtered by capacitors to remove AC ripple. Has voltage divider resistor for screen voltage.
PostPosted: Jan Fri 13, 2017 10:50 pm
Thanks for the help. Moderator Please close this. Thanks
Post New Topic Post Reply  [ 4 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: No registered users and 16 guests
