It is currently Oct Mon 15, 2018 6:33 pm
 Post subject: Cap incident and a few questions
PostPosted: Dec Tue 05, 2017 2:58 am
Hello all
I’m working on an RCA C-122, which I have not been able to locate a schematic, and thought I was done. It was recapped, except for the electrolytics as they looked to be newer, and was playing great for about 30 min. Then I heard the old unmistakable hissss which was followed by smoke. The cap in the attached link was the culprit, I’m assuming, as it’s split laterally. It is across pins 4 and 7 of the 35W4. Can someone assist with its value? The color code looks like yellow, purple orange then a dark color I cant make out, a space then yellow or gold. Secondarily, what could be the possible cause? Bad electrolytic perhaps? I’ll replace them regardless. Thanks for any help.
Rod
https://photos.app.goo.gl/dDBrj3aGcBsFSA8X2
 Post subject: Re: Cap incident and a few questions
PostPosted: Dec Tue 05, 2017 3:15 am
That one should have been the first capacitor you replaced.........it's an infamous Sprague Black Beauty, and they are notorious for exploding quite loudly and even catching fire.
It's a .047 @ 400 volts, but I wouldn't replace it with the same type. You can use a modern "safety type" capacitor in it's place to avoid the same thing happening in the future should the new one ever fail.
PostPosted: Dec Tue 05, 2017 3:17 am
Yellow = 4
Violet = 7
Orange = x1000
47000 pf = 0.047 mfd
http://www.electronics-tutorials.ws/cap ... cap_5.html
It's also known as "bumble bee" style paper capacitor. Known for high failure rate. Very likely died due to old age.
"What goes around comes around." (Karma)
PostPosted: Dec Tue 05, 2017 3:52 am
Bumble Bee caps came in two variety's, paper in oil and Mylar film. If they have the solder blob on the end sealing the fill spout they are paper in oil, if there is no solder blob they are Mylar and probably still good.
Black Beauty's also came in the same variety's as the Bumble Bees but had no stripes. The ones with red lettering were Mylar and the yellow lettering were paper in oil and have a solder blob.
The paper in oil capacitors usually have very high leakage and should always be replaced. They will still work in low voltage applications like guitar tone controls and are in demand and fetch high prices for desired values.
PostPosted: Dec Tue 05, 2017 5:04 am
Always an education; thanks to all for the great info!
Rod
PostPosted: Dec Sat 09, 2017 2:13 am
If you're going to recap, recap, don't leave old caps behind because they "look newer". Newer could be 40 years old. Old caps especially bumblebees and similar plastic-cased types, regardless of how they work, are just time bombs. On old radios brought back in service after many decades, they will often work for a few minutes or hours, then decide to short or explode. I've seen radios where every one of these was cracked or split open. I wouldn't risk burning out a rare tube by not replacing a cap that literally costs pennies to replace.
PostPosted: Dec Sat 09, 2017 4:51 pm
Sound advice and lesson learned. To be honest, I thought the bumblebee was a power resistor initially. After it lost its smoke, I tested it on a component tester which ID’d it as a cap of 30pfd. Won’t happen again!
Rod
PostPosted: Dec Sat 09, 2017 9:21 pm
Hi Rod,
30pfd is WAY too low for a Black Beauty cap. Here's the color code explanation:
The values are in pfd, but usually 10,000 or more.
These little gems are ALWAYS bad. They were oil-filled paper (except 200v had no oil). The seal fails and the oil leaks out, leaving an oilless paper cap with a voltage of maybe 100 volts.
- Leigh
73 de W3NLB
http://www.AtwaterKent.info
PostPosted: Dec Sat 09, 2017 9:36 pm
Leigh wrote:
Hi Rod,
- Leigh
Thanks for that Leigh
PostPosted: Dec Mon 11, 2017 2:02 am
I had one that went off like a firecracker. Split right in half, a better cutaway view could not have been intentionally made.
PostPosted: Dec Mon 11, 2017 2:09 am
Rod
A component tester probably won't correctly identify a part after it has failed.
Jim Mueller
PostPosted: Dec Mon 11, 2017 3:11 am
I have serviced radios where the bumblebee exploded, paper/foil confetti and Bakelite crumbs all over the chassis :shock:
Post New Topic Post Reply  [ 12 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: Chas and 14 guests
