It is currently Jul Fri 20, 2018 9:45 am
 Post subject: WYTBRADIOMAN NEEDS SOME HELP
PostPosted: Dec Tue 05, 2017 6:41 am
CAN ANYONE TELL ME HOW TO REWIRE THE ELECTROLYTIC CAPS FOR A RCA RADIOLA? I HAVE THE MANUAL FOR THE RADIO, STILL DON'T KNOW TO PLACE THE +AND - OF THE CAPS.
 Post subject: Re: WYTBRADIOMAN NEEDS SOME HELP
PostPosted: Dec Tue 05, 2017 2:14 pm
There are several kinds of caps. You want to be concerned with the Electrolytic and paper caps. leave in round discs alone(MICA)
Only the electrolytic need + & _ to be concerned with, for the most part, not counting 'foil' caps (negative indicated foil shielding)
There are several threads here already dealing with this in detail. Lets use one of those for pre-req reading for you.
https://www.google.com/search?q=replaci ... radios.com
Joe @ Vintage Test Equipment - There's no shortage of cruelty to animals: http://joinASPCA.org
PostPosted: Dec Tue 05, 2017 2:37 pm
Which Radiola model do you have?
https://www.radiolaguy.com/radiola.htm
PostPosted: Dec Tue 05, 2017 2:55 pm
There are two cardinal rules to help determine polarity:
In a conventional transformer set:
The most positive point is the cathode of the rectifier.
The most negative point is the center tap of the HV winding.
-Mark http://pixellany.com
PostPosted: Dec Tue 05, 2017 3:33 pm
The Caps Lock key is a toggle. Push it again and you will exit WW2 US Navy text mode.
PostPosted: Dec Tue 05, 2017 3:40 pm
Unless its TTY, then all caps is SHOUTING!
Caps? Duh, use poly/metalized, no polarity , no worries...
PostPosted: Dec Tue 05, 2017 4:06 pm
You may be right guys, but don't you think we should not rule out possible "accessibility" issues?
73, de Chuck K4CCW
"The question is not what you look at, but what you see." Thoreau
Post New Topic Post Reply  [ 7 posts ]  Moderators: Marcc, Norm Leal
