It is currently Jul Fri 20, 2018 9:44 am
 Post subject: Philips Model A3 259 14 Radio Question
PostPosted: Dec Wed 06, 2017 4:08 am
I'm restoring a Philips Model A3 259 14 radio and I can't find any schematics. There appear to be two resistors going to an EZ80 tube. They each start smoking when the radio is turned on. I can't tell what value they are because they have no markings, only an orange dot painted on one end.
 Post subject: Re: Phiilips Model A3 259 14 Radio Question
PostPosted: Dec Wed 06, 2017 4:53 am
A3 259 14 is not the model number... :)
It will be listed as Type on the Masonite back or on the chassis as seen here.
from here: https://www.radiomuseum.org/r/philips_b3ln66u_35.html
PostPosted: Dec Wed 06, 2017 11:25 am
Is this an example of turning it on unchecked to see if it works? The highest probability, with a set like that is: It won't. That sort of practice commonly gives me extra, often expensive work, repairing the avoidable damage.
Two resistors the same, of a type I find unreliable, as the cap comes off, suggests that they are on pins 1 & 7 of the EZ80 (6V4). If so, apart from surge control, these are usually a low wattage resistor, or a "Fusistor" the purpose of which is to self destruct on overload. If you have not checked or replaced all of the electrolytic capacitors & checked it for shorts & deterioration & wax paper caps which I suspect it has: Stop now.
and inspect it.
Marc
 Post subject: Re: Philips Model A3 259 14 Radio Question
PostPosted: Dec Wed 06, 2017 1:27 pm
There is no label on my radio, only a space above the "A3 259 14". And no, this wasn't turned on unchecked. It had already been worked on and it was working for a few days then the reception started fading and the resistors started smoking.
PostPosted: Dec Wed 06, 2017 11:27 pm
No clarity, as to where the resistors are? I am at this point, not convinced that something (including rectifier) is not shorting.
Marc
PostPosted: Dec Thu 07, 2017 12:09 am
Can you post a photo of the front of the radio
and a top-view of the chassis?
What are the tubes in your radio?
PostPosted: Dec Thu 07, 2017 5:11 pm
What are the measurements on both, same resistance? Not too many pins available for connections. One resistor generally for divider connected to pin 3 (guess). Possible resistor from who knows where to filament for ground. Where do the other ends connect?
Bill J.
PostPosted: Dec Fri 08, 2017 1:58 am
Here are some photos of the radio including the tube placement found on the back cover.
PostPosted: Dec Fri 08, 2017 3:20 am
You have seen the record changer... right... Lol
Philips H5X 68 A manufactured in Holland 1956
19 page service manual in English... :)
https://www.doctsf.com/grandlivre/fiche ... 759&ori=ps
oh... The doctsf.com (télégraphie sans fil) pdf's are untagged, you may have to add .pdf to the end of the downloaded file!
Edit: Codification des appareils Philips.
https://www.doctsf.com/dossiers/codif_philips.php
PostPosted: Dec Sat 09, 2017 5:54 pm
Thank you! This is great.
Post New Topic Post Reply  [ 10 posts ]  Moderators: Marcc, Norm Leal
