It is currently May Wed 23, 2018 2:08 pm
 Post subject: Phillips Bi-Ampli BX998A
PostPosted: Dec Thu 07, 2017 4:43 am
So I picked up this radio, and I likely spent too much on it, but that's another story. Anyway, there appear to be several issues with it after I get it home and start inspecting it, and I'm really hoping someone has some experience working on one of these and/or could share some tuning string diagrams or something.
Here's the issues...
1. There is a stray wire hanging off the bottom of the chassis. The wire might be designed to connect to the bottom cover which has a lining of foil on it, but who knows.
2. The tuning eye is actually a knob that I assume was used to rotate the internal antenna, but that string is broken.
3. The white plastic backdrop behind the needles is broken on the end where it connects and is just hanging in place, or I might say out of place.
4. There are several strings that are loose and I have no idea where they should be.
5. The tuning needle for the FM band appears to be tucked away or bent or something not sure which.
6. The string to control the treble/bass is broken so the needle doesn't move on that display.
The radio does work though, have used it on FM when tuning manually, but who wants to do that all the time? :)
Any help would be greatly appreciated!
 Post subject: Re: Phillips Bi-Ampli BX998A
PostPosted: Dec Thu 07, 2017 4:46 am
Some pictures...
PostPosted: Dec Thu 07, 2017 5:00 am
27 pages of service data here...
https://www.doctsf.com/grandlivre/fiche ... 546&ori=ps
Holy smokes... Make sure you take your blood pressure medication before looking at the stringing diagrams. Lol
oh... The doctsf.com (télégraphie sans fil) pdf's are untagged, you may have to add .pdf to the end of the downloaded file!
PostPosted: Dec Thu 07, 2017 6:44 am
SIXTEEN dial strings!?!?!
I knew it looked like a big tangle in the back of the one I just picked up.
I didn't know HOW big. :cry:
PostPosted: Dec Thu 07, 2017 8:33 am
Radiomuseum.org has a complete set of service info for this set including control cord stringing. Unfortunately, unless one is a member only 10 sheets can be downloaded per 30-day time period.
With regard to the "hanging wire"... it probably is the bonding wire that connects the electrostatic shield foil on the bottom cover. If it is, it will be soldered to the steel chassis on its "connected" end. The "floating" end should be soldered to a flat ring terminal and retained by one of the bottom cover screws.
The dial backs on these sets were often sheets of parchment paper or thin translucent plastic held in place by spring clips. If one of the clips has come loose it can probably be re-installed. If the sheet is torn it will need to be replaced. I've used translucent Mylar sheets (same stuff used by design draftsmen in pre-CAD days)... it is tough and strong. But thin white sheet styrene will work OK, too, and may give a more original appearance.
PostPosted: Dec Thu 07, 2017 8:44 am
wow... I'm not going to enjoy this at all.
Thanks for the pdf links, the first one will be useful, but unfortunately the other two service docs are not english. If I need them I might see about exporting the text via OCR to google translate.
PostPosted: Dec Thu 07, 2017 8:47 am
Thanks... any idea where I could get such sheets?
PostPosted: Dec Thu 07, 2017 11:12 am
I would love that, take me through the winter.
Wow! Philips sure could make a radio: should have a few Bowden cables as well :D
Forunately Philip components are very good if they were still making their own by then. May not need a lot of waxie swapping but obviously check all crital ones.
OCR of data is laborious, did a bit for a German D57 and couldnt find a free one that was very accurate, to be expected really 'cos of all the technical terms. Needs a lot of deciphering and correcting before the translate. But look around for similar Philips radios that sold to the UK or the US as their manuals gave me a lot of help by cross refering.
Gary
PostPosted: Dec Thu 07, 2017 3:28 pm
Go to Amazon.com and type in "Mylar drafting film" or "styrene plastic sheets". Office supply stores may still carry mylar film; hobby stores which cater to scratchbuilders will probably stock thin styrene sheets under the Evergreen brand name.
PostPosted: Dec Thu 07, 2017 3:36 pm
You may need to prevail on a German-speaker (or Dutch-speaker, depending where the set was made) to help you decipher the service info. Translation software seems to do a very poor job when it encounters "technese". If you've done a couple of alignments, however, you can probably figure out what the gist of the procedure is.
PostPosted: Dec Fri 08, 2017 10:35 am
Hi there!
Through a Google Alert set on 'BX998A' this discussion was brought to my attention. I first had to register to this forum that I didn't know yet, before I could write this message. I am a Dutch RF- and antenna design engineer, and (currently not-active) ham radio operator. I just might be the one who can help you out with this endeavor. I too am the proud owner of this marvelous Philips BX998A radio, already since the seventies, and I used its wide SW coverage for amateur radio reception back then. Even built in a SSB detector for that purpose. Some years ago I completely renovated the radio to its original state. Actually, I own two of these radio's at the moment, as I bought a second one that was nonfunctional and repaired and renovated that one as well.
I have a paper copy of the full service documentation of the BX998A, and could make a scan of it in full for you, at no costs, output in pdf. However, there are many fold-out pages that you would have to assemble again from loose page scans like a big jigsaw puzzle. Furthermore, the text is in Dutch. I could do my best to translate it, but English or American English is not my native language, and all of these quite mechanical terms would cause me a headache to translate :-) But I could just help you to decipher bits and pieces of it later on.
Please beware that it will be a hell of a job to renovate your radio, you will need endless patience and good mechanical and electrical skills. And unless you have a spectrum analyzer and vector network analyzer, you should definitely not touch the many RF and IF transformers. You can completely ruin them, as their magnetic cores are easily broken when you attempt to turn them with a screw driver just like that. Also note that there are some not so obvious facts about this radio, such as the speakers seemingly being connected out-of-phase, but they should, as they are also driven that way.
I don't know if it is allowed to mention e-mail adresses here, but I better don't anyway. You can find my contact information on my website, search for ElegAnt Solutions Enschede. Then we can discuss further. This is not commercial. I would be glad to be of help, provided you don't ask too much of me :-)
Best regards, Hans.
PostPosted: Dec Sat 09, 2017 12:05 pm
I thought I had seen a pic and a write up of this radio before: there was a 2 page article in the BVWS Bulletin, Spring 2007.
It wont give you much restoration help (18 dial cords !!) but does go into operation and the owner was thrilled with its performance and sound.
Can scan the pages and Email them if you want them (send me a PM with address)
Gary
PostPosted: Dec Wed 13, 2017 6:08 pm
PA3AZA - Thanks for the offer of help, may reach out to you at some point if I need it.
I was able to rework the FM tuning belts. It has a cloth belt and wire belt used for FM... not sure why but it's working for now. There are several other belts that are still out because they are broken that I'll get around to eventually, but for now it is playing FM fairly well.
One issue when playing on the FM band is that when I step away from the radio, the signal drops out, but when I stand right next to it, it comes in clear. Any idea what might be happening here? My amateur mind is assuming it has something to do with the bottom cover that's currently off. That cover has a metal mesh on it that I assume should connect to a loose wire hanging out the bottom.
PostPosted: Dec Wed 13, 2017 6:20 pm
This set has an internal FM antenna consisting of a twinlead dipole that is stapled to the inside of the cabinet. These are fairly effective antennas but they cannot be easily aimed. You might try unplugging the built-in antenna and substituting something like an old TV set "rabbit ears". Adjusting this external dipole antenna should allow you to eliminate the influence of your body on the signal received by the set. You are essentially "steering" the radio signal with your body, which is an interesting effect but not particularly conducive to operating satisfaction.
The bottom mesh is an electrostatic shield and is mostly intended to prevent local oscillator signal radiation out of the set (where it could interfere with other nearby radios) rather than intrusion of random RF.
PostPosted: Dec Wed 13, 2017 6:33 pm
Thanks! I'll keep that in mind. Right now the radio is sitting on a box that's on a roller, so we'll see how it performs in it's new location when I get around to moving the existing radio out of it's way. :)
PostPosted: Dec Wed 13, 2017 7:45 pm
I worked on some other model of upper end, large Philips radio a few years ago which also contained a zillion little strings and stuff. Let me just say that as someone who has worked on a lot of German and Euro sets, even Saba, that I probably won't be working on any of these if I can help it. They are such a mess!
PostPosted: Dec Wed 13, 2017 7:58 pm
@Radios2100: I think your problem with the internal antenna is that you have plugged it in the wrong way. I say this referring to the picture of the backside above. The plug should be horizontally inserted, the two pins come in the two upper(left) holes. Rgds, Hans PA3AZA.
PostPosted: Dec Wed 13, 2017 8:20 pm
You are right, according to the diagram, I believe it should be the top left holes. I moved the plug and it didn't help with the reception, it seems to work just as well in either position.
PostPosted: Dec Thu 14, 2017 12:20 pm
Disappointing reception with the built-in antenna, and no improvement when using the top left holes for connection, can be caused by the fact that many radio broadcasts are being transmitted vertically polarized these days. The built-in dipole is essentially intended for horizontally polarized signals.
Therefore even if you insert the antenna plug the right way (in the upper left holes) your reception may still be not very good. Then, if you insert the plug the wrong way, as in the picture, the antenna does not work as a dipole but merely as some random length of wire instead. Which just may or may not yield good results.
Best thing would be to insert the antenna plug the right way, and then put your radio on its left or right side, so that the built-in dipole antenna is vertical iso horizontal :shock: :wink: Not being serious.
Regards, Hans PA3AZA.
PostPosted: Dec Thu 14, 2017 7:19 pm
English manual: https://www.staff.science.uu.nl/~tel001 ... 998Aen.pdf
I'm in Florida settling my Father's estate and can take some detailed pictures when I return to Pennsy... if you can wait that long...
Jim
Never met a Philco I didn't like!
Users browsing this forum: Chas and 12 guests
