It is currently Feb Wed 20, 2019 8:14 pm
Post New Topic Post Reply  [ 131 posts ]  Go to page 1, 2, 3, 4, 5 ... 7  Next
 Post subject: rogers majestic r-841
PostPosted: Nov Sat 04, 2017 12:55 pm
Looking for the schematic for the rogers majestic r-841 radio , thanks from a0e 1k0 nl Canada.
 Post subject: Re: rogers majestic r-841
PostPosted: Nov Tue 07, 2017 2:03 am
Thanks for all the help but I have now ordered the schematic on line.
PostPosted: Nov Wed 08, 2017 9:58 am
I am about to start to recap it and it has grey boxes with the capacitors so are they chassis grounded and are any caps higher voltage then 450v.
PostPosted: Nov Wed 08, 2017 12:55 pm
The schematic will tell us how the caps are wired. If in doubt, post a snip** of the section showing the capacitor.
As for the voltage rating, does the schematic list any DC Voltages?
** open the file and crop down to the area in question. Then scale to 600 pixels or less on the longest side---so the file size will be small enough.
-Mark http://pixellany.com
PostPosted: Nov Mon 13, 2017 10:25 am
Have not had time to look at radio yet been so busy but would a picture of section I am going to work on first help thanks.
PostPosted: Nov Mon 13, 2017 12:22 pm
I would need to see all or part of the schematic. Ideally, post a link to the schematic. Otherwise, post a picture of the portion of the schematic that shows the electrolytics.
PostPosted: Nov Mon 13, 2017 1:49 pm
This is all I can find using Rogers and "841". Does this match up to what you have? (Chassis number 841)
https://www.radiomuseum.org/r/rogerstub ... s_725.html
PostPosted: Nov Tue 14, 2017 12:51 am
That is the same has what I have.
PostPosted: Nov Tue 14, 2017 1:05 pm
The schematic at Radiomuseum is one of the worst I have ever seen. If yours is better, please send me the file. (i'll send a PM with my e-mail address)
If yours is no better, I suggest you make a new schematic before starting work.
PostPosted: Nov Tue 14, 2017 10:11 pm
the one I have is not really any better but someone must have a good one.
PostPosted: Nov Tue 14, 2017 10:53 pm
I would not assume that.....
PostPosted: Nov Tue 14, 2017 11:32 pm
There must be a original copy somewhere or would that not be any better
PostPosted: Nov Tue 14, 2017 11:50 pm
Also I believe it was the same in cabinets 725 730 740 and 750 .
PostPosted: Nov Wed 22, 2017 2:05 am
Did anyone find a better schematic thanks , they all seem to be hard to read.
PostPosted: Nov Wed 22, 2017 12:48 pm
I suggested earlier that you may have to draw your own. I would start with the one that is available, but draw it in the modern format...showing the tube PIN numbers, etc.
PostPosted: Nov Wed 22, 2017 2:55 pm
Maybe this might help....Download on top right of the page.
https://app.box.com/s/gm0867jfy7zjcrtwob0oa9wfms4eozkx
or if you prefer
https://app.box.com/s/lmy05sawavkk5yni8mcal1ucroeo6mjq
Regards
Ken
PostPosted: Nov Wed 22, 2017 4:57 pm
Nice!!---where are those from?
for SP: The + side of the 2 main filter caps is the top end on the schematic. 450-volt rating is fine for the electroltyics
PostPosted: Nov Wed 22, 2017 10:05 pm
Thanks that is a real good schematic and thanks marc also.
PostPosted: Dec Thu 07, 2017 10:49 pm
Here is a couple of picture of which I am not sure the connection.
PostPosted: Dec Thu 07, 2017 10:50 pm
Another picture
Post New Topic Post Reply  [ 131 posts ]  Moderators: Marcc, Norm Leal Go to page 1, 2, 3, 4, 5 ... 7  Next
Users browsing this forum: fields 100, Google Adsense [Bot], sillyrabbit, simplex1040 and 10 guests
