Page 1 of 1
[ 15 posts ] |
Author |
radiodale1
Post subject: Worst Philco Block Repair Technique Posted: Jan Tue 02, 2018 12:38 am |
Joined: Jun Mon 01, 2015 9:34 pm Posts: 929 Location: Greenville, TX
Starting to recap a Philco 630 and found two terrible block repairs. Two terminals were CUT OFF of each block and the new caps tied on in the air without any support! Terminals were still attached to the components.
_________________ Dale
http://www.dalesantiqueradio.com/
Top |
Radioroslyn
Post subject: Re: Worst Philco Block Repair Technique Posted: Jan Tue 02, 2018 1:10 am |
Joined: May Fri 01, 2015 2:33 am Posts: 1272 Location: Roslyn,Pa 19001
Top |
radiodale1
Post subject: Re: Worst Philco Block Repair Technique Posted: Jan Tue 02, 2018 1:17 am |
Top |
radioalfa
Post subject: Re: Worst Philco Block Repair Technique Posted: Jan Tue 02, 2018 1:32 am |
Member |
Joined: Aug Mon 20, 2012 12:23 pm Posts: 1441 Location: Groveland MA
The same guy must have worked on the Philco 60 that I just finished. Same technique.
Russ
_________________ A place for everything, everything in it's place. I just don't remember where all those places are.
Top |
rugged
Post subject: Re: Worst Philco Block Repair Technique Posted: Jan Tue 02, 2018 1:37 am |
Same guy was in a Philco 80 I am starting on. Components flying through the air all over the place.
Top |
badwaxcaps
Post subject: Re: Worst Philco Block Repair Technique Posted: Jan Tue 02, 2018 2:36 am |
Joined: May Thu 26, 2011 5:58 am Posts: 3712 Location: Capon Bridge, WV
Those blocks are a pain but make for a nice clean re-stuff job when done properly.
_________________ Consider me a straw in your haystack of success.
Top |
radiodale1
Post subject: Re: Worst Philco Block Repair Technique Posted: Jan Tue 02, 2018 4:26 am |
Top |
35Z5
Post subject: Re: Worst Philco Block Repair Technique Posted: Jan Tue 02, 2018 4:02 pm |
Member |
And the sets worked for probably 25-40 years with these repairs... No real doubt, were good enough...
_________________ Tom
Top |
N9whh
Post subject: Re: Worst Philco Block Repair Technique Posted: Jan Wed 03, 2018 1:01 am |
Member |
Joined: Oct Wed 01, 2014 1:20 pm Posts: 174 Location: Wood River, Ill.
It must be a pretty common technique, even though I hate it, but I have seen it done that way in almost every Philco I have worked on. I suppose the Philco blocks were not readily available to anyone but a Philco dealer/service tech. Capacitor sizes of the Day were too large to restuff the blocks. Leaving them hanging with out tieing down is just poor practice, though. I have seen enough of that done too.
_________________ 73 Chris N9WHH
Top |
Tom Albrecht
Post subject: Re: Worst Philco Block Repair Technique Posted: Jan Wed 03, 2018 1:09 am |
Member |
Joined: Jan Thu 01, 1970 1:00 am Posts: 12525 Location: San Jose, CA USA
If speed and money are all that count, then he did it the right way. Sure looks ugly, however!
_________________ Tom K6VL
Top |
stromberg6
Post subject: Re: Worst Philco Block Repair Technique Posted: Jan Wed 03, 2018 1:39 am |
Joined: Apr Mon 24, 2006 1:05 am Posts: 2342 Location: Ellington CT
If you are fortunate enough to have unmolested blocks, it's not THAT hard to de-pot the blocks if done carefully. Could be done in an old toaster oven no longer used for food while watching closely. I have un-potted capacitor and transformer blocks in wax and tar on a gas grille, again, watching very carefully. If you are married, and your spouse doesn't share your enthusiasm for the hobby, don't try it in the kitchen oven LOL.
_________________ "There Is Nothing Finer Than A Stromberg-Carlson"
Top |
Peter Bertini
Post subject: Re: Worst Philco Block Repair Technique Posted: Jan Wed 03, 2018 4:51 am |
Moderator |
Joined: Jan Thu 01, 1970 1:00 am Posts: 22625 Location: Somers, CT
Early repairmen did not have the luxury of miniature radial lead caps that could be easily inserted into a cleaned out shell.
_________________ Just because it can be done doesn't mean it should be done.
Top |
radiodale1
Post subject: Re: Worst Philco Block Repair Technique Posted: Jan Wed 03, 2018 5:56 am |
He could have drilled thru the rivets on the block and then added the caps externally. Did not have to clip the terminals.
Top |
Peter Bertini
Post subject: Re: Worst Philco Block Repair Technique Posted: Jan Thu 04, 2018 3:38 am |
Moderator |
They were paid to repair, not restore, back when those sets were daily players in homes. A lot of early repair work would be considered shoddy and lazy today.
Top |
munali
Post subject: Re: Worst Philco Block Repair Technique Posted: Jan Thu 04, 2018 1:20 pm |
Joined: Aug Fri 21, 2009 7:45 pm Posts: 810 Location: Port Dover, Ontario
Unless the sloppy work has been done with modern components, I would not be too critical of the repairs.
Fixing a chassis to earn your daily bread is something quite different than doing it as a hobby where time is not so demanding.
Joseph
Top |
