It is currently Jan Wed 23, 2019 8:16 am
 Post subject: Zenith 10S669 anomalies
PostPosted: Jan Wed 03, 2018 8:31 pm
I am restoring a Zenith 10S669 and keep finding inconsistencies between the schematic and the actual radio. The schematic is consistent with my chassis number.
The radio has 3 bands: BC, POL. and SW. However, now that I have partially dismantled the chassis I discover that the band switch, 4 wafers with switch contacts on 6 sides, has 4 positions. What is going on?
Other anomalies:
R16 on the schematic does not exist, the cathode of the 6J5 inverter is wired directly to the cathode of 6F5 amp.
C6 between GND and pin 3 of 7G7-1232 R.F. exists but is .02uf instead .05uf as indicated by the schematic
There is a 220K resistor from 6J5 OSC. pin 5 (grid) to GND which is not shown on the schematic.
There is at least one other anomaly but I haven't yet traced the full circuit involved. There is evidence that someone has been in the radio before but I don't believe all the circuit wiring and component anomalies result from earlier "repairs".
Any thoughts, especially regarding the 4 position band switch?
Every little bit helps. Thanks.
 Post subject: Re: Zenith 10S669 anomalies
PostPosted: Jan Wed 03, 2018 8:43 pm
The fourth position should be for the push buttons; (Automatic).
If the parts that vary from the schematic are original, I'd assume that they could be changes in the run at the factory.
If not, then go with the schematic. I had one of these a long time ago, and they sound very good when they are
rebuilt.
Frank
KD0RUC
PostPosted: Jan Thu 04, 2018 7:19 pm
brimill,
What is the serial number listed on the chassis? It should begins with a letter followed by six numbers.
Martin
Concentrating on collecting pre-WWII Zenith radio models for the EXPORT market
Post New Topic Post Reply  [ 3 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: binaryxy and 11 guests
cron
