It is currently May Sun 26, 2013 4:57 am
 Post subject: Is this 80 tube bad?
PostPosted: May Fri 25, 2007 1:51 pm
I have an old balloon style 80 rectifier tube with white "flakes" rolling around inside. Is this normal, or is it not safe to use? My tube tester doesn't test these old style tubes, so I have no way of testing. The filament checks good with a meter though.
Glenn
PostPosted: May Fri 25, 2007 2:32 pm
Glenn
This is cathode coating that has flaked off. Some emission will be lost with that much flaking. If the tube still has enough emission it's safe and usable. Since you can't test an 80 try it in a radio.
PostPosted: May Sat 26, 2007 2:17 pm
Thanks Norm. I was curious what that stuff was.
Are these vintage tube difficult to come by?
Glenn
PostPosted: May Sat 26, 2007 3:08 pm
The number 80 in shoulder style (ST) is common as dirt.
The number 80 in globe style (S) can be rather spendy if you need to purchase one from a vendor.
PostPosted: May Sat 26, 2007 10:12 pm
I assume the newer "ST" type is backward compatible with the older "S" type tubes. I guess it just doesn't look right in a set of this time period.
Glenn
PostPosted: May Sat 26, 2007 10:56 pm
As far as the radio operation, it makes no difference...
I have one that has even more flakes than yours, works fine in a Radiola 18 and a Philco 610(yea It's too old for that one)... It does test a little weak and voltage(B+) in the radios is down slightly(vs a strong tube), but they don't seem to care...
PostPosted: May Tue 29, 2007 9:16 pm
Come to find out, my tester does have the 4 pin sockets for these old tubes.
Norm-
You were right, the tube tests around 50% for one half, and 55% for the other. It's a little low, but it should still work.
The good news is that all the other tubes in the radio test okay. I guess I got my money's worth for $20.
Thanks again everyone.
Glenn
Post New Topic Post Reply  [ 7 posts ]  Moderators: Marcc, Norm Leal
Users browsing this forum: Radioguy52, Steve Davis and 4 guests
