It is currently May Sat 25, 2013 5:15 am
 Post subject: Cleaning & Polishing Brass ...
PostPosted: May Thu 10, 2012 4:32 pm
I have some solid Brass pieces to a 1950 Raytheon TV that I am trying to clean and polish:
I've soaked the pieces in lacquer thinner overnight and rubbed with fine steel wool but still cannot get the pieces cleaned of the old finish. I got the larger door piece pretty clean but the round pieces I'm having trouble with.
Any ideas?
 Post subject: Re: Cleaning & Polishing Brass ...
PostPosted: May Thu 10, 2012 4:57 pm
Assuming they are solid brass, you will have no problem ripping them out with a buffer and some hard polish.
PostPosted: May Thu 10, 2012 8:26 pm
They are solid brass. I scratched the back and its brass color in the scratch. And, a magnet will not stick to it.
Got one stubborn piece where the protective finish just will not come off.
Tried steel wool and polishing - wonder if it is lacquer.
Soaking it in lacquer thinner hoping it will soften it up.
PostPosted: May Thu 10, 2012 11:15 pm
Paint remover?
PostPosted: May Fri 11, 2012 6:24 am
Have you tried Brasso?
PostPosted: May Fri 11, 2012 11:42 am
After soaking overnight in fresh Lacquer Thinner I was able to clean it off with fine steel wool.
I'm a novice doing Brass restoration.
One other issue I found is that after cleaning and polishing I used spray can clear lacquer to protect the brass. The lacquer did not cover perfectly smooth - sort of a crinkly effect. Not unappealing but not what I was wanting. Any hints, tips regarding spraying lacquer?
PostPosted: May Fri 11, 2012 3:55 pm
You need better conditions and more skill to lacquer brass and other metals. Lacquering wood is child's play in comparison. :) It should be 75-80 degrees, less than 30% humidity and NOT windy or breezy. The metal should be heated and washed with a solvent. Cover very lightly and wait a long time in-between coats. Metal can't absorb lacquer so it will be much more 'touchy' than normal.
PostPosted: May Sat 12, 2012 12:04 am
I think I had everything wrong.
The Temp was 70 degrees and it was after a rain - but I was inside my garage with door up.
Did not heat the metal either.
Next time I'll use your tips.
PostPosted: May Sat 12, 2012 3:57 am
I've had good luck coating metals with acrylic. Again, light coats and let dry completely. Even if it says fast drying, acrylic can take a few weeks to cure fully.
Post New Topic Post Reply  [ 9 posts ]  Moderator: Peter
