It is currently May Fri 24, 2013 12:36 pm
 Post subject: How to deal with bubbles in veneer?
PostPosted: Jun Fri 29, 2012 5:23 am
Your experiences in dealing with bubbles in veneer would be much appreciated. I was discussing this with a friend, but given my talent for screwing-up things which are close to being finished, thought I'd try to find as many ideas as possible. If I use the finest needle to inject watered-down glue, should I clamp it, or just hold it with my thumb? How do I deal with the potential for cracks. This is on the top, and I've already got most of the clear on the cabinet, probably just one heavy coat of lacquer on the top away from being ready to rub it with the fine abrasives.
Many of my radios are on my http://www.photobucket.com account - FStephenMasek.
My company website is http://www.masekconsulting.net
 Post subject: Re: How to deal with bubbles in veneer?
PostPosted: Jun Fri 29, 2012 1:42 pm
You MUST clamp the bubble after injecting the glue! Also, clamp it down with a piece of wood so that there are no clamp marks when you are finished. Leave the clamps on overnight- don't rush it.
Pete
PostPosted: Jun Fri 29, 2012 4:13 pm
Don't forget to put a piece of wax paper over that bubble first before clamping a piece of wood on it. If any of that glue comes back out, it will glue that block to the veneer!! Carl.
PostPosted: Jun Fri 29, 2012 5:30 pm
I'd add a piece of rubber under the block, to conform to the surface. I might also give the lacquer a few more days to harden first.
PostPosted: Jun Fri 29, 2012 11:05 pm
Bubbles & Veneer...didn't they used to do the morning show at KMPC?
Mike Koste
Gobs of Knobs
Ambler, PA
PostPosted: Jun Sat 30, 2012 1:55 am
I've taken care of bubbles by slicing a few times with the grain using a razor and then rubbing a slightly thinned glue solution with my fingers into the slices. The cuts are very thin and close back up nicely. Clamp with wax paper--yes.
PostPosted: Jun Sat 30, 2012 3:14 am
Thanks. I'll work on it tomorrow. I've used wax paper when making other repairs, and it is quite handy for the purpose.
PostPosted: Jul Sun 01, 2012 6:45 am
I have found if you use a water soluble (probably not spelled correctly) like elmers even if some of the glue comes out you can wipe it with a damp cloth even after the glue has dried and get the excess off. I think it is best to try to appy the glue sparingly and not be tempted to apply to much. Otherwise you have more to do after you take the clamps off.
Mac
Zenith
Crosley
GE
Philco
RCA
PostPosted: Jul Sun 01, 2012 8:20 pm
I managed to dent one spot by clamping too hard, so now have to deal with that...., but still thing I have the final coat on lacquer on it by the end of today.
