It is currently Jan Tue 22, 2019 5:38 pm
 Post subject: Zenith 7g605 handle
PostPosted: Mar Fri 23, 2018 11:48 pm
How do the metal handle pieces attach to the case. I need to replace the handle.
 Post subject: Re: Zenith 7g605 handle
PostPosted: May Wed 16, 2018 11:08 pm
Late reply, but the handle brackets are held on by rivets that are splayed on the ends and difficult to remove. I think the easiest way is to carefully drill out the center piece that goes through the hole in the leather handle and replace that with a blind brass screw (round head with no slot).
You can then drill a small hole in the cabinet and attach it with a nut on the inside of the case. The handle would hide the hole, but unfortunately I have not yet found a source for the correct size blind brass screws.
John KK4ZLF
Post New Topic Post Reply  [ 2 posts ]  Moderator: Peter
Users browsing this forum: Steve Davis and 4 guests
