It is currently May Thu 23, 2013 11:39 am
 Post subject: ?? Reproducing brass plates and tags....
PostPosted: Feb Mon 27, 2012 5:06 pm
I seem to recall seeing instructions on repro'ing brass plates and tags here - or, perhaps, somewhere else online. Does anyone have that info - or a link to it ???
JG Jackson
"Uva Uvam Videndo Varia Fit"
 Post subject: Re: ?? Reproducing brass plates and tags....
PostPosted: Feb Tue 28, 2012 6:36 pm
Are you talking about something like this?
http://gasengine.farmcollector.com/Equi ... lates.aspx
Curtis Eickerman
PostPosted: Feb Tue 28, 2012 11:19 pm
That's exactly what I was looking for............. Thanks Curtis.
JG Jackson
PostPosted: Mar Fri 02, 2012 6:30 am
I did this one for my A-K Type "M" horn, which was missing its label when I got it. I used a mixture of hydrogen peroxide and hydrochloric acid for the etchant, and cheap semi-glossy photo paper from K-Mart for the toner transfer. Printer used was an HP Laserjet 4000. The template was made using a combination of MS Paint and GIMP 2.6 (which is a free download, and enabled me to "curve" the "MADE IN U.S.A." around the center hole for the mounting screw). The etchant solution I used is cheaper than ferric chloride (and also produces cupric chloride as it etches, increasing the effectiveness of the etchant), but it DOES need to be used in a well-ventilated space. ANyway, here is the finished result:
Post New Topic Post Reply  [ 4 posts ]  Moderator: Peter
