It is currently May Tue 21, 2013 3:58 pm
Post New Topic Post Reply  [ 47 posts ]  Go to page 1, 2, 3  Next
 Post subject: Amazing what a little Go-Jo can do!
PostPosted: Feb Sat 18, 2012 6:55 am
I remember reading on here once someone said to use #000 steel wool and non-pumice Go-Jo to remove years of dirt and gunk off an old finish. I thought this radio looked darn good like it was before, but after this test spot, I did the entire unit with Go-Jo and it looks brand new! It's crazy! I've been Go-Joing wood finishes all day! :D
Btw...can you "Guess That Radio!" ? :)
William D.
Saving America's acoustical history, one phonograph at a time..
 Post subject: Re: Amazing what a little Go-Jo can do!
PostPosted: Feb Sat 18, 2012 10:13 am
Its even more amazing what westleys cleaner can do
PostPosted: Feb Sat 18, 2012 12:28 pm
You should switch to 0000 steel wool, it's a little
easier in the finish.
I've been using it for more than 30 years, it's the
best treatment I've ever found, in fact we call it
"The Treatment". after the finish gets good and dry
apply several coats of Old English scratch cover,
when it's completely dry, you can wipe it with a clean
paper towel and get no brown on it, then start
piling on the Johnson's Paste Wax, use your bare
hand to apply the wax, the heat from your skin
will help the wax get in deep.
As many coats as you feel like doing, buffing it off
between. The finish will have the best protection
you can give it.
Welcome to the club of confirmed users of
"The Treatment".
73, Ron w4ron
http://antiqueradiocharlotte.homestead.com
PostPosted: Apr Sat 21, 2012 6:40 am
Is'nt Go-Jo oily and leave residue behind??? It seams like a strange thing to clean a radio with. Question, why to you use steel wool instead of just a cloth rag????
Lynn
PostPosted: Apr Sat 21, 2012 7:16 am
philcolynn wrote:
Is'nt Go-Jo oily and leave residue bTLYehind??? It seams like a strange thing to clean a radio with. Question, why to you use steel wool instead of just a cloth rag????Lynn
Oily? ABSOLUTELY NOT.
It cuts the build up of greasy dirt on the finish, I've used
it on dozens of radios and other antiques. The 0000 steel
wool is used to break the surface of the dirt and let the cleaner
do it's job.
Radios that I've told would require refinishing have been
turned into award winners after cleaning and waxing.
Try it, I know you'll like it, it's never failed me.
73, Ron w4ron
PostPosted: Apr Sat 21, 2012 7:27 am
Here's photo of my wife's grandmother's kitchen table
that sat in the middle of her kitchen from 1927 until
we took it home in 1995.
It was just about black with a darkened finish.
The black grease build-up just melted off with the
Go-Jo, I've since put on about 15 coats of Johnsons Paste
Wax. It's solid 3/4" oak and It just glows!
73, Ron w4ron
PostPosted: Apr Sat 21, 2012 9:16 am
you can give it.
"The Treatment".
can you use that directly over new stain. I don't want to use any polyurethane and want to give my philco some luster and protection
DIGITAL CIRCUITS ARE MADE WITH ANALOG PARTS
PostPosted: Apr Sat 21, 2012 4:03 pm
There'd be no need to use Go-Jo over new stain, it's just a cleaner.
Now the wax, absolutely use it over new stain, and pile it on, the more
coats the better. And the best but a little messy way to apply wax is
with your bare hand, the heat from your skin helps the wax lay down
better. I just use white paper towels to buff it off, then just throw them
away and get a clean one.
73, Ron w4ron
PostPosted: Apr Thu 26, 2012 4:01 am
Ron, Thanks for answering my question!! I'd like to give your instructions a go at. A question, when useing the steel wool do you work in circles or up and down, back and forth? Also is one cleaning enough? Where do you get your paste wax at? I am in a small town but we have a home depot and menards. Hey, thanks for all the info I am excited to give it a try. I will do before and after pictures!!
A very excited Lynn :D
PostPosted: Apr Thu 26, 2012 3:45 pm
philcolynn wrote:
Ron, Thanks for answering my question!! I'd like to give your instructions a go at. A question, when useing the steel wool do you work in circles or up and down, back and forth? Also is one cleaning enough? Where do you get your paste wax at? I am in a small town but we have a home depot and menards. Hey, thanks for all the info I am excited to give it a try. I will do before and after pictures!! A very excited Lynn :D
I don't think it matters what direction you go in,
JUST DON"T BARE DOWN ON THE STEELWOOL.
The weight of your hand should be enough, repeat as
many times as it takes until you can wipe up the used Go-Jo
and it still be white. If it's still brown or black, you're still taking
off dirt.
I buy my Johnson's Paste Wax at Lowes or Home Depot.
I look forward to seeing your results.
73, Ron w4ron
PostPosted: Apr Fri 27, 2012 4:46 am
Ron, Thanks for all the great info!! I will keep you informed on how it is going!
Huge Thanks!!! :D
Lynn
PostPosted: Apr Sat 28, 2012 8:39 pm
works great on antiques of all kinds..........especially old clocks :)
buck
PostPosted: Apr Sun 29, 2012 10:18 am
This is a gramophone cabinet I did with the stuff.
I dont use steel wool though. I just scoop some out with my hand & rub it on with my hand. Then I use paper towels to wipe the dirty sludge off. I also do what most people dont, and that's wipe everything down with a slightly damp cloth once I'm finished.
Most of what came off this cabinet I think was nicotine.
Shane
PostPosted: Apr Sun 29, 2012 10:33 am
That's a great side by side comparison, good work.
I found a cruddy old battery set cabinet that someone tossed
in the trash pile after the Charlotte meet that I'm going to
try sectioning off and cleaning and waxing and then a section
that's untouched. to show what can be done.
Using your hand is interesting, but I've never hurt anything
with 0000 steelwool. I do use my hand to rub in wax, I think
the heat of my skin helps melt the wax so it penetrates better.
I also always use Old English scratch cover between the cleaning
and waxing, it really helps.
73, Ron w4ron
PostPosted: Apr Sun 29, 2012 10:48 pm
I too use go-jo and 0000 steel wool with good results but this photo tells it like 1000 words could not:
PostPosted: Apr Mon 30, 2012 3:24 am
Bruce, Fantastic Job!!! :D Wow that is a huge difference!! Thanks for posting the picture it really dose tell a thousand words!!!!! Be sure to post a picture when all done!!! :D
Many Thanks!!!!!
Lynn
PostPosted: Apr Mon 30, 2012 4:01 am
I was at Menards and Home Depot today looking fo Go Jo and everything had pumice.
Can someone post a picture of the container I should be looking for in the store?
Art's Antique Radio Collection - A work in progress
http://www.myantiqueradio.com
PostPosted: Apr Mon 30, 2012 2:12 pm
It will be in a white container, orange seems to indicate the presence of pumice:
http://www.amazon.com/GOJO-1115-Origina ... 030&sr=8-7
Sometimes it's easier to find Goop, which is basically the same thing. I recently saw some at Harbor Freight in a handy squeeze tube:
http://www.harborfreight.com/catalogsea ... ult?q=goop
Just remember to get a white container, not orange.
PostPosted: Apr Mon 30, 2012 2:28 pm
That's right, the white container and Goop is just as good as Go-Jo,
73, Ron w4ron
PostPosted: May Wed 02, 2012 12:40 am
Hi ho hi ho it's off to harbor freight I go!
Post New Topic Post Reply  [ 47 posts ]  Moderator: Peter Go to page 1, 2, 3  Next
Users browsing this forum: chinobob, Eliot Ness and 2 guests
